  • Nisreen Al-Masri 12 posts 91 karma points
    Jul 20, 2017 @ 09:27
    Nisreen Al-Masri
    Slide problem after upgrading till 7.6.4
    Hello
    Umbraco v7.5.11 is uppgraded to 7.6.4 is successfully
    the slide and carousel things worked fine with previous version but now getting null reference!
    the error is stuck here
    var imageUrl = !String.IsNullOrEmpty(slide.Url) ? slide.Url : Umbraco.TypedMedia(mediaId).Url;
    The media picker has a problem I guess.
    anyone tried this before in the newer version?
    please help:)
    Jul 20, 2017 @ 10:09
    Alex Skrypnyk
    Hi Nisreen
    Did you disable property value converter on Umbraco?
    Check out, please : https://our.umbraco.org/documentation/Getting-Started/Setup/Upgrading/760-breaking-changes#property-value-converters-u4-7318
    Alex
    Aug 11, 2017 @ 06:04
    Nisreen Al-Masri
    Hi Alex:
    Thanks for ur suggestion but actually I checked that before
    <!-- Enables value converters for all built in property editors so that they return strongly typed object, recommended for use with Models Builder -->
    <EnablePropertyValueConverters>true</EnablePropertyValueConverters>
    and it is true:(
    Aug 11, 2017 @ 07:44
    Alex Skrypnyk
    HI Nisreen
    It should be "false" if you don't want to change the code.
    Alex
    Jul 26, 2017 @ 21:28
    Alex Skrypnyk
    Hi Nisreen
    Did you solve the issue? Please, share with our community.
    Alex
