  • Manish 373 posts 932 karma points
    Jul 25, 2017 @ 08:25
    Manish
    How to use peta-poco
    This is my first time to use peta-poco. I don't have any idea how to use this. Is there any example for latest version which can help me to start with.
    Please help me on this
    Manish
  • Johan Reitsma 68 posts 234 karma points MVP 2x
    Jul 25, 2017 @ 08:33
    Johan Reitsma
    there are many examples you can find on the internet.
    This one is an example http://www.wiliam.com.au/wiliam-blog/using-petapoco-with-umbraco-is-pretty-sweet
    Jul 25, 2017 @ 08:54
    Manish
    Thanks for replying me
    Do i need to install anything in version umbraco version 7 to start with ?
    Manish
    Jul 25, 2017 @ 09:13
    Alex Skrypnyk
    Hi Manish
    You have to install nothing. Peta POCO is part of the core now. Just be sure that you use this references:
    using Umbraco.Core;
    using Umbraco.Core.Persistence;
    Alex
    Jul 25, 2017 @ 09:16
    Manish
    Thanks Alex
    I am just beginning sample for poco but don't have idea where to start. Link provided above is bouncer to me is there any more sample which looks simple for poco beginner with more detail.
    Manish
    Jul 25, 2017 @ 09:25
    Johan Reitsma
    101
    I don't know your knowledge level, but its pretty easy.
    If you have an object you can map that to a database table. Columns map using attributes. Google has a lot of simple examples but you need basic level of understanding SQL and attributes.
    Here is an other example: https://creativewebspecialist.co.uk/2013/07/16/umbraco-petapoco-to-store-blog-comments/
    Alex Skrypnyk
    Peta POCO is a smal ORM, it's easy to access database with peta POCO, nothing special.
    What do you want to do with petaPOCO?
    THanks,
    Alex
    Jul 25, 2017 @ 09:27
    Manish
    Hi Alex
    I want to create a page in CMS which perform CRUD operation with custom tables.
    Manish
    Alex Skrypnyk
    It's exactly what can do peta POCO, create table with petaPOCO and do CRUD operations with it.
    Jul 25, 2017 @ 09:34
    Alex Skrypnyk
    Table creation example:
    using Umbraco.Core;
    namespace MyDemo.Web.Logic.Extensions
       public class RegisterEvents : ApplicationEventHandler
           protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
               var db = applicationContext.DatabaseContext.Database;
               if (!db.TableExist("wilCompetition"))
                   db.CreateTable(false);
    POCO class:
    using System;
    using Umbraco.Core.Persistence.DatabaseAnnotations;
    namespace MyDemo.Web.Data.Poco
       [TableName("wilCompetition")]
       [PrimaryKey("Id", autoIncrement = true)]
       public class Competition
           [PrimaryKeyColumn(AutoIncrement = true)]
           public int Id { get; set; }
           public string Name { get; set; }
           [Column("CompetitionDescription")]
           [NullSetting(NullSetting = NullSettings.Null)]
           [SpecialDbType(SpecialDbTypes.NTEXT)]
           public string Description { get; set; }
           public DateTime CreatedOn { get; set; }
    Alex
    Alex Skrypnyk
    Peta POCO uses the same connection string as Umbraco.
    Jul 25, 2017 @ 11:21
    Manish
    Thanks to all
    Now able to start :)
