  • Manish 373 posts 932 karma points
    Jul 31, 2017 @ 06:54
    Manish
    How to set GUID as primary key in peta poco apprach
    I am using peta poco but no idea how to set primary and foreign key as GUID.
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Jul 31, 2017 @ 08:47
    David Brendel
    Hi Manish,
    on your class you can use an attribute to set your PrimaryKey:
    [PrimaryKey("Id", AutoIncrement = false)]
    So your primary key would be named Id and is of type Guid.
    That should work.
    Regards David
    Jul 31, 2017 @ 09:07
    Manish
    Many thanks David B :)
    Jul 31, 2017 @ 09:32
    Manish
    When I am updating model properties then it is not reflecting directly in table, First I need to delete the old table and run the project then it creates new table with changes. I there any way to migrate changes in table without deleting the table.
    Jul 31, 2017 @ 10:37
    David Brendel
    Hi Manish,
    have a look at umbraco migrations. Basically a class inheriting from MigrationBase.
    With that you have an up/down method where you can do changes on your tables.
    https://cultiv.nl/blog/using-umbraco-migrations-to-deploy-changes/
    Regards David
    Jul 31, 2017 @ 12:28
    Manish
    This works only when i create migration script manually but i want the way to create migration script dynamically [add-migration] same as entity frame work in mvc approach. In MVC approach there is an option in manage console to create migration script by [add-migration].
    I want approach something like this https://docs.microsoft.com/en-us/aspnet/mvc/overview/getting-started/getting-started-with-ef-using-mvc/migrations-and-deployment-with-the-entity-framework-in-an-asp-net-mvc-application
    Please suggest on above query.
    Jul 31, 2017 @ 13:22
    David Brendel
    Hi Manish,
    that's not possible in Umbraco. You have to create the migrations by hand.
    Regards David
