Understanding code references from Fanoe on Umbraco 7.6.3
3 questions in regards to Fanoe for Umbraco version 7.6.3
When I load the Fanoe home page, there is a background image within the grid-section. From chrome developer tools, when I inspect the page the element, it looks like this...
I can't find this style attribute in BackOffice. How did it get
implemented onto the div element?
You can find this element in the grid layout in the backoffice.
Try to mark the row with the banner and click on the settings icon then you should see this.
I can't find folder /1044 under the media section in BackOffice. How
is it that this folder exist at the file level of Umbraco, but not
in BackOffice? Try to see this issue on the tracker. http://issues.umbraco.org/issue/U4-5957 that is why you can“t find the images in the backoffice.
On the master template, there is the following element...
Umbraco version 7.6.3When I load the Fanoe home page, there is a background image within the grid-section. From chrome developer tools, when I inspect the page the element, it looks like this...
<div style="background-image:url(/media/1044/14441035391_7ee1d0d166_h_darken.jpg);>...</div>I can't find this style attribute in BackOffice. How did it get implemented onto the div element?
I can't find folder /1044 under the media section in BackOffice. How is it that this folder exist at the file level of Umbraco, but not in BackOffice?
...can I use
@(home.SiteLogo)in a stylesheet? or is this only available to do on templates?Thanks!
Hi blackhawk
I will try to answer your questions
I can't find folder /1044 under the media section in BackOffice. How is it that this folder exist at the file level of Umbraco, but not in BackOffice? Try to see this issue on the tracker. http://issues.umbraco.org/issue/U4-5957 that is why you can“t find the images in the backoffice.
You can only do the @ in the template or a partial view file or partial view macro file because it the sign for starting the razor engine.
Hope this helps.
/Dennis
