  • Manish Agrawal 25 posts 218 karma points
    Aug 10, 2017 @ 07:32
    Manish Agrawal
    Create Nullable field with PetaPoco Model
    I am using petapoco to create custom table in database.
    Now I want to change int and datetime property as NULLABLE. so I have set (?) with property datatype.
    public int? TotalNumber { get; set; }
    I have deleted the tables and running the project. It is creating new table with not Nullable field.
    Please suggest what I am missing.
    Aug 11, 2017 @ 05:19
    Manish Agrawal
    It will be good if any one can reply on it.
    when I am trying to create table with nullable fields it is creating not nullable fields in tables.
    Please suggest what is the approach to make this in petapoco. I have done this many times in MVC entity framwork but this is not working here.
    Regards Manish
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Aug 11, 2017 @ 07:41
    David Brendel
    Hi Manish,
    don't think this is possible with PetaPoco when creating the table with the poco. You could try creating the schema by sql. At least I now that with that you could set a field to nullable.
    Alter.Table(yourTable).AddColumn("TotalNumber").AsInt32().Nullable();
    Maybe this works.
    Regards David
    Aug 11, 2017 @ 12:29
    Manish Agrawal
    Thanks David for reply.
    but this will not help in my problem.
    I will wait Peta poco new versions if they fix this problem in new versions.
  • Marcio Goularte 389 posts 1362 karma points
    Aug 11, 2017 @ 14:48
    Marcio Goularte
    9
    Add this attribute: [NullSetting(NullSetting = NullSettings.Null)]
    UPDATE: Does it work with DateTime, I use it in a project.
    public DateTime? Suporte { get; set; }
