Hi, I get this error when trying to upgrade. Is there any workaround?
I use Nuget
ERROR: The database configuration failed with the following message:
An explicit DROP INDEX is not allowed on index 'umbracoNode.IXumbracoNodeUniqueID'.
It is being used for UNIQUE KEY constraint enforcement.
Please check log file for additional information (can be found in '/AppData/Logs/UmbracoTraceLog.txt')
Help: Error when upgrading Umbraco from 7.1.3 to 7.6.5
Hi, I get this error when trying to upgrade. Is there any workaround? I use Nuget
ERROR: The database configuration failed with the following message: An explicit DROP INDEX is not allowed on index 'umbracoNode.IXumbracoNodeUniqueID'. It is being used for UNIQUE KEY constraint enforcement. Please check log file for additional information (can be found in '/AppData/Logs/UmbracoTraceLog.txt')
