  • Bhavesh Jadav 35 posts 144 karma points
    Aug 17, 2017 @ 09:14
    Bhavesh Jadav
    Save and publish not working
    We have one site in umbraco version 7.3.0.
    We are not able to save and publish content, when we are clicking on Save and Publish button
    But we are able to save and publish media,template,css, scripts files from umbraco cms.
    We have try below options but still issue not resolved:
    • Permissions of files and folders on server
    • Restarting website in IIS
    • Deleted umbraco.config and republished site
    • Recycling application pool
    • Touch the web config file
    • Incremented the version at /config/ClientDependency.config
    Please help me to solve this issue. I searched for this error. but didn't get proper solution.
    Thank you in advance.
  • Arunabha Das 38 posts 151 karma points
    Aug 17, 2017 @ 09:53
    Arunabha Das
    What kind fo error you are getting... Will help if you check the Umbraco logs under app_data
    Aug 17, 2017 @ 10:16
    Bhavesh Jadav
    getting below errors in UmbracoTraceLog.txt
    ERROR Umbraco.Core.Sync.DatabaseServerMessenger - DISTRIBUTED CACHE IS NOT UPDATED. Failed to execute instructions
    ERROR Umbraco.Web.Scheduling.ScheduledPublishing - Failed
    Aug 17, 2017 @ 10:58
    Arunabha Das
    if you want to cold boot your site, delete the App_Data/TEMP/DistCache folder and restart the site - this will bypass all instructions and reset your site to latest try to update the executionTimeout since instructions are processed in a request thread currently and this is why you get the Thread was being aborted. exception
    Aug 17, 2017 @ 12:22
    Bhavesh Jadav
    Thanks for your help.
    Issue has been resolved now.
    For further ref: http://issues.umbraco.org/issue/U4-7673
