  • manoj 4 posts 84 karma points
    Aug 17, 2017 @ 14:41
    manoj
    IContent and IPublishedContent return null for the other tabs properties
    I am having two tabs in the page. when I trying to access the properties using IContent and IPublishedContent, I am able to access the properties of the first tab but for second tab property its returning null.
    Can anyone suggest how I should I access my second tab properties while iterating?
    foreach (IContent local in localsNode.Children()){
    // Getting null for the second tab property
    var questionInsight = local.Properties["questioninsight"].Value.ToString();}
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Aug 28, 2017 @ 13:39
    Alex Skrypnyk
    Hi Manoj
    There is no difference what tab are you using, try to get values as for the first tab.
    You need only property alias for getting the data from the property.
    Alex
    Sep 12, 2017 @ 14:20
    Alex Skrypnyk
    Hi Manoj
    Did you fix the issue? Can you share with our community?
    Alex
    Sep 13, 2017 @ 04:09
    manoj
    Hi Alex,
    Yes, i was able to retrieve the other tabs as the child element of the node.
    Thanks for your suggestion...
