In my previous job we developed a site as an Intranet - weekly newsletters, call centre user guide (v large), and ideas for expansion...
We didn't use AD for access as there was no sensitive information to protect.
Umbraco is an ideal solution for an intranet, but at the end of the day it does depend on requirements - there might be products better suited / OOTB / etc.
I simply love using Umbraco and so it would be my "go to", and then others would have to convince me not to use it (and that would take a big stick) haha :-)
may be that will be https://our.umbraco.org/projects/collaboration/uintra/ interesting for you. we are using Umbraco for set of success Intranets for our client for our company internally. we integrated it with AD, CRMs, asp.net membership and so on... u are welcome free to contact me, if you have questions.
The media archive is open in Umbraco. I believe there are som plugins that can handle it but should be a part of core in my concerns. A media item should contain attributes as a documenttype with publish and unpublish.
Anyways, this is a huge disadvantage when using Umbraco as intranet, but it is easy to solve if you are aware of the problem. I would recommend Umbraco when building intranets but don't forgett to protect your documents!
Umbraco for Intranet
Has anyone used Umbraco as an Intranet tool? If so, were there any caveats? If it was considered and not used, why?
Hey DrewMac
Cheers, Nigel
Hej
vadym
Hi, The media archive is open in Umbraco. I believe there are som plugins that can handle it but should be a part of core in my concerns. A media item should contain attributes as a documenttype with publish and unpublish.
