I'm using Umbraco 7.6.4 and somehow when I was testing the auto publish and auto unpublish feature, this doesn't seem to work at all as it never gets published / unpublished...
I've looked the issue up earlier, and tried the solutions I found, but it didn't helped much...
I've also tried adding the url in the umbracoSettings in the web.routing part umbracoApplicationUrl
But this didn't seem to help either...
Update: I just tried it again, clicked on save, and saw this error in my logs:
2017-08-24 11:50:38,046 [P22000/D37/T54] ERROR Umbraco.Web.Scheduling.ScheduledPublishing - Request failed with status code "Unauthorized". Request content = "".
System.Net.Http.HttpRequestException: Request failed with status code "Unauthorized". Request content = "".
Update: I have changed the authentication settings for the /Umbraco folder to enable annonymous and now I don't get any errors in my logs anymore, but it also still doesn't publish / unpublish on the given time...
Update: Have been trying some more things and it seems that right now the auto publish function works, sadly the auto unpublish doesn't work yet...
Update: Sometimes it seems to work, other times it doesn't? o-o
Well, the issue seems to be fixed after enabling Anonymous Authentication for the /Umbraco directory.
Even though I had a bunch of issues with it not working / not working properly, this might maybe have been cause some cached things? Not sure, it was pretty weird, but it seems to be working now...
Auto publish / unpublish not working?
Hi there,
I've looked the issue up earlier, and tried the solutions I found, but it didn't helped much... I've also tried adding the url in the umbracoSettings in the web.routing part
umbracoApplicationUrlBut this didn't seem to help either...
/Umbracofolder to enable annonymous and now I don't get any errors in my logs anymore, but it also still doesn't publish / unpublish on the given time...Update: Have been trying some more things and it seems that right now the auto publish function works, sadly the auto unpublish doesn't work yet...
Does anyone have a clue on what might solve this?
Thanks in advance!
Anonymous Authenticationfor the/Umbracodirectory.Even though I had a bunch of issues with it not working / not working properly, this might maybe have been cause some cached things? Not sure, it was pretty weird, but it seems to be working now...
