Removing <span> and <p> tags from shortened RTE content
I need to display the first 200 or so characters from some content entered in an RTE. Right now I have accomplished this using a function that truncates whatever string you input to a desired length. Right now it removes the
tag, that appears at the start, by letting the substring start at index 3, but sometimes other tags are added as well.
public static string TruncateAtWord(string input, int length)
if (input == null || input.Length < length)
return input;
int iNextSpace = input.LastIndexOf(" ", length, StringComparison.Ordinal);
return string.Format("{0}...", input.Substring(3, (iNextSpace > 0) ? iNextSpace : length).Trim());
This works fine, though it doesn't take into account the added tags the RTE creates, which are returned when I use the ToString() method.
How can I take into account the extra tags that the RTE creates behind the scenes when i shorten my content? Is there a way for the RTE to not use these tags, since I already have the text wrapped in a p tag?
However, it may be easier / less risk of something breaking in the middle of the night to have an additional field for this excerpt that uses the textarea property editor, rather than the rich text editor.
Whenever i need to strip out the HTML from the RTE output i tend to use the following helper method passing in the alias of the RTE property from the doc type.
library.StripHtml()
If i want to truncate the content to a certain number of characters i use something like so
var contentSnippet = Umbraco.Truncate(library.StripHtml(Model.Content.GetPropertyValue<string>("mainContent")), 120, true);
and then output the truncated snippet without html
<p>@contentSnippet </p>
Hopefully that is what you were trying to achieve?
The function itself is called like this :
Html Agility pack can be used for this purpose, see: https://stackoverflow.com/questions/12787449/html-agility-pack-removing-unwanted-tags-without-removing-content
excerptthat uses the textarea property editor, rather than the rich text editor.Hi Thomas,
Paul
Hi Guys,
Here are a few helper methods. I usually add these in as String Extension Methods.
I haven't used them in a long time so please give them a good test.
