    Aug 29, 2017 @ 13:18
    Ismail Mayat
    Load balance on azure index rebuild issue
    So I have on azure umbraco 7.5.13 site. Its a master slave setup. So we have backoffice as master and frontend as slave. Front end does not have /umbraco access. I have followed instructions on our and have set up master slave registrations.
    Two things when my site loads I do not see any entries in the umbracoserver table. The other thing is the internal index will not build. External one builds fine. The error log when rebuilding internal index does give the following error:
    at Examine.LuceneEngine.Providers.LuceneIndexer.RebuildIndex() in X:\Projects\Examine\Examine\src\Examine\LuceneEngine\Providers\LuceneIndexer.cs:line 752 at UmbracoExamine.UmbracoContentIndexer.RebuildIndex() at Umbraco.Web.WebServices.ExamineManagementApiController.PostRebuildIndex(String indexerName) ClientConnectionId:ed65fabc-42be-4c41-9096-5dfee842d32c Error Number:-2,State:0,Class:11 ClientConnectionId before routing:88382140-7485-4377-9d3a-ab58663fea6e Routing Destination:xxxxxxxx,11023
    I have stripped out the db server and replaced with xxxxxxx. On the backoffice master I can login and get to content tree etc so its hitting the db with connection string I have in the web.config. Anyone seen this before?
    Regards
    Ismail
    Aug 29, 2017 @ 14:37
    Ismail Mayat
    So a bit more information it looks like http://issues.umbraco.org/issue/U4-7869 we do have 70k items altogether.
    I have also found that we can increase time out https://github.com/umbraco/Umbraco-CMS/pull/1097/files will give that a go see if that works.
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Aug 29, 2017 @ 15:24
    Jeavon Leopold
    Give that a try, also what type of DB (S0, S1, etc) do you have and have you checked to see how the DTU utilisation is when building the indexes?
    Aug 29, 2017 @ 15:45
    Ismail Mayat
    Jeavon,
    I am slowly bumping up dtus its making a difference also increased timeout but think i just need to keep going till it builds. cheers.
    was on s0 im on s2 now with 50 dtus
    Ismail
    Aug 29, 2017 @ 15:49
    Ismail Mayat
    Jeavon,
    That did the trick s2 50 dtus.
    Regards
    Ismail
    Aug 29, 2017 @ 15:53
    Jeavon Leopold
    Ah yes, S0 is tricky, it does work as long as you increase the timeout but S1 is recommended minimum for Umbraco. If you can try to get a elastic pool with a few different projects in it, can make it cheaper and you have more burstable eDTUs.
  • Shannon Deminick 1530 posts 5278 karma points MVP 4x
    Aug 30, 2017 @ 00:12
    Shannon Deminick
    umbracoserver is only in use for master election, if you follow the recommended practice here https://our.umbraco.org/documentation/Getting-Started/Setup/Server-Setup/load-balancing/flexible#scheduling-and-master-election then master election does not occur and therefore this table is not populated.
    Some people have asked that we continue populating this table regardless for informational purposes and it's something I'm sure we can do but at the moment that isn't a priority (PRs welcome! :)
    Have you tried out 7.6.5 ? IIRC there are performance enhancements in versions greater than the one you are using.
    Aug 30, 2017 @ 15:46
    Ismail Mayat
    In the flexible load balancing docs there is setting:
    directoryFactory="Examine.LuceneEngine.Directories.SyncTempEnvDirectoryFactory,Examine"
    do we need this? We have got the azure bits setup. So atm our config looks like:
      <add name="ExternalIndexer" type="UmbracoExamine.UmbracoContentIndexer, UmbracoExamine"
           useTempStorage="Sync"
           tempStorageDirectory="UmbracoExamine.LocalStorage.AzureLocalStorageDirectory, UmbracoExamine"/>
    regards
    Ismail
    Aug 30, 2017 @ 10:46
    Ismail Mayat
    Shannon,
    Not tried updating as client wont pay for it so we are stuck on 7.5. Increasing timeouts and dtus has got the indexes rebuilding.
    Regards
    Ismail
    Aug 30, 2017 @ 16:00
    Jeavon Leopold
    If you have Examine v0.1.80+ then use the directoryFactory otherwise what you have is what is recommended for pre v0.1.80
    Aug 30, 2017 @ 16:05
    Ismail Mayat
    i got 0.182 so keep both azure bits and directoryfactory or just directoryfactory?
    Regards
    Ismail
    Aug 30, 2017 @ 16:07
    Jeavon Leopold
    Just directoryFactory
    Here is our ExamineSettings.config Azure transform file:
    <?xml version="1.0"?>
    <!-- For more information on using app.config transformation visit http://go.microsoft.com/fwlink/?LinkId=125889 -->
    <Examine xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
        <ExamineIndexProviders>
            <providers>
                <add directoryFactory="Examine.LuceneEngine.Directories.TempEnvDirectoryFactory,Examine"  xdt:Transform="SetAttributes" />
            </providers>
        </ExamineIndexProviders>
    </Examine>
    Aug 30, 2017 @ 16:09
    Jeavon Leopold
    Make everything so much simpler than it used to be :)
    Aug 30, 2017 @ 16:14
    Jeavon Leopold
    SyncTempEnvDirectoryFactory is available in Examine v0.1.80+
    This is equivalent to what you had before but "better"
    TempEnvDirectoryFactory is only available in Examine v0.1.83+
    This is even better as it doesn't need to sync and you don't have to tokenise the index paths
