  • Manish Agrawal 25 posts 218 karma points
    Aug 31, 2017 @ 10:30
    Manish Agrawal
    How to create custom module in CMS area with Peta Poco
    I have created a customized CMS application in umbraco with petapoco. I am adding all steps to create.
    1. Create Tree Controller
      [Tree("myapp", "jobs", "Home")]
      [PluginController("MyApp")]
      public class HomeTreeController : TreeController
      protected override TreeNodeCollection GetTreeNodes(string id, FormDataCollection queryStrings)
      TreeNodeCollection nodes = new TreeNodeCollection();
      if (id == "-1")
          foreach (Link leftLink in LinkRepository.Current.GetAll())
              if (leftLink.Id == 1)
                  nodes.Add(CreateTreeNode(leftLink.Id + "", id, queryStrings, leftLink.Name, "icon-thumbnails", false, "/myapp/dashboard"));
              else if (leftLink.Id == 2)
                  nodes.Add(CreateTreeNode(leftLink.Id + "", id, queryStrings, leftLink.Name, "icon-add", false, "/myapp/create"));
              else if (leftLink.Id == 3)
                  nodes.Add(CreateTreeNode(leftLink.Id + "", id, queryStrings, leftLink.Name, "icon-folder", false, "/myapp/draft"));
      return nodes;
      } protected override MenuItemCollection GetMenuForNode(string id, FormDataCollection queryStrings) { return new MenuItemCollection(); } }
    Aug 31, 2017 @ 10:33
    Manish Agrawal
    1. Trees.config
    Add this line at last in trees.config.
    <add initialize="true" sortOrder="0" alias="jobs" application="myapp" title="Home" iconClosed="icon-folder" iconOpen="icon-folder-open" type="MyApp.Web.Controllers.HomeTreeController, MyApp.Web" />
    Aug 31, 2017 @ 10:36
    Manish Agrawal
    1. application.config
    Add this line in application.config.
    <add alias="myapp" name="My App" icon="icon-newspaper" sortOrder="0" />
    You can add this in any position where you want and change the sort order accordingly.
    Aug 31, 2017 @ 10:41
    Manish Agrawal
    1. route.js
    If you want to set this is page as default in CMS then need to modify route.js.
    .when('/:section', {
                templateUrl: function (rp) {
                    if (rp.section.toLowerCase() === "myapp" || rp.section.toLowerCase() === "umbraco" || rp.section === "") {
                        rp.section = "myapp";
                        return '/App_Plugins/myapp/backoffice/jobs/dashboard.html';
                    else {
                        if (rp.section.toLowerCase() === "default") {
                            rp.section = "content";
                        rp.url = "dashboard.aspx?app=" + rp.section;
                        return 'views/common/dashboard.html';
                resolve: canRoute(true)
    Aug 31, 2017 @ 10:58
    Manish Agrawal
    Aug 31, 2017 @ 11:08
    Manish Agrawal
    1. Database Queries
    I was facing connection issues with petapoco if I was calling queries separately, so I used QueryMultiple, This is good one.
    @0 is indicating parameter what you are passing in QueryMultiple after sql. you can pass multiple parameters (@0, @1, @2, .... so on).
    public class Model1
                public int JobCount { get; set; }
        public int JobDate { get; set; }
    public class Model2
        public Guid JobId { get; set; }
        public string Title { get; set; }
    public class AppViewModel
        public Model1 Model1{ get; set; }
        public List<Model2> Model2 { get; set; }
    string sql = @"Select * from table1 where date=@0
                          Select * from table2 where date=@0";
    var result = new AppViewModel();
            using (var multi = EntitiesDB.QueryMultiple(sql,
    DateTime.Now.DefaultSqlDateTime()))
                result.Model1 = multi.Read<Model1>().FirstOrDefault();
                result.Model2 = multi.Read<Model2>().ToList();
    Sep 06, 2017 @ 06:45
    Manish Agrawal
    1. Folders and File Structure of custom module
    MyApp is custom module so
    View path is : App_Plugins/MyApp/BackOffice/Jobs/name.html
    Controller path is : App_Plugins/MyApp/BackOffice/Controllers/name.js
    We will use Angular Js to call actions.
    Sep 06, 2017 @ 06:50
    Manish Agrawal
    1. API controllers
    public partial class HomeController : UmbracoAuthorizedApiController
    Create a API controller which will inherit UmbracoAuthorizedApiController.
    [HttpGet]
        public object ShowPanel(int linkId) {
            Link link = LinkRepository.Current.GetById(linkId);
            if (link == null) return Request.CreateResponse(HttpStatusCode.NotFound);
            return link;
    Sep 06, 2017 @ 06:53
    Manish Agrawal
    1. Dashboard.js
      angular.module('umbraco').controller('MyApp.Dashboard.Controller',
        function ($scope, $routeParams, $http) {
      $http.get('/umbraco/backoffice/api/Home/ShowPanel').success(function
      (response) {
          $scope.Panel = response;
    Sep 06, 2017 @ 06:55
    Manish Agrawal
    1. Dashboard.html
       <div ng-controller="MyApp.Home.Controller">
       <div>{{Panel}}</div>
    Sep 06, 2017 @ 06:59
    Manish Agrawal
    1. package.manifest
    Add entry of js file in package.manifest.
    "javascript": [
        "~/App_Plugins/MyApp/Controllers/CreateJob.js",
        "~/App_Plugins/MyApp/Controllers/EditJob.js",
        "~/App_Plugins/MyApp/Controllers/Dashboard.js"
