  • nibbe 9 posts 99 karma points
    Sep 04, 2017 @ 13:36
    nibbe
    Images not showing after deploy
    Hey!
    I got a working solution on my local environment set up on a iis. Everything is working good, BUT after I deploy the project to one of surftowns servers I cant see any images at all!
    Every images has the corrent url in the html markup, but if I take a look inside the browser inspector it says, /login.aspx?ReturnUrl=%2fmedia%2f1125%2fautoliv_120.png Failed to load resource: the server responded with a status of 404 (Not Found)
    I read something about permissions and I have all the rights permissions set on the media catalog.
    Any suggestions my fellow developers?
    Sep 04, 2017 @ 14:33
    Alex Skrypnyk
    Hi Nibbe
    Are you using some media protection packages?
    Did you set up iis access to your umbraco folder?
    Alex
  • Edvin Mujalo 6 posts 76 karma points notactivated
    May 04, 2022 @ 14:42
    Edvin Mujalo
    Hi Nibbe,
    Did you find a solution for this? I have exactly the same problem with Umbraco 9.
    After deploying, my images are no longer displayed. I also found out that the images are not deployed.
    I may need a blob storage for the pictures or is there another way?
    Thanks, Edvin
