Back in Umbraco 7.5.2, we were able to modify the web.config to allow our child application to run.
site.com (Umbraco) site.com/app (Child App)
All we needed to do was make sure these elements:
<appSettings> <system.web> <system.webServer>
were inside of the following tags...
<location inheritInChildApplications="false"> </location>
...and everything was fine. With Umbraco versions 7.6.3 & 7.6.5, after making this modification, all of the images are now returning a 500 error.
Has anyone else had the same problem and are there any available workarounds at the moment?
Any advice would be greatly appreciated.
Peace be upon those who follow guidance,
@Chris, can you post the web.config of child app and the template markup part where aspitelogo.png exists?
web.config
Here is the web.config:
<?xml version="1.0" encoding="utf-8"?> <configuration> <configSections> <sectionGroup name="NWN.ControlLibrary.SectionGroup"> <section name="SmartLabel" type="NWN.ControlLibrary.Utility.ConfigSectionHandler, NWN.ControlLibrary" /> </sectionGroup> <sectionGroup name="applicationSettings" type="System.Configuration.ApplicationSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"> <section name="XXXXXX.Web.Properties.Settings" type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false" /> </sectionGroup> <!-- For more information on Entity Framework configuration, visit http://go.microsoft.com/fwlink/?LinkID=237468 --> <section name="entityFramework" type="System.Data.Entity.Internal.ConfigFile.EntityFrameworkSection, EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false" /> </configSections> <connectionStrings> <remove name="XXXXXX.ClassLibrary.My.MySettings.XXXXXX4ConnectionString" /> <remove name="XXXXXX.Data.XXXXXXDBContext" /> <add name="XXXXXX.ClassLibrary.My.MySettings.XXXXXX4ConnectionString" connectionString="XXXXXXXXXXXXXXXXXXXX" providerName="System.Data.SqlClient" /> <add name="XXXXXX.Data.XXXXXXDBContext" connectionString="XXXXXXXXXXXXXXXXXXXXXXXXX" providerName="System.Data.SqlClient" /> </connectionStrings> <NWN.ControlLibrary.SectionGroup> <SmartLabel> <ConnectionString value="XXXXXXXXXXXXXXXXXXXXXX" /> </SmartLabel> </NWN.ControlLibrary.SectionGroup> <appSettings> <!--- excluded --> </appSettings> <location path="." inheritInChildApplications="false"> <system.web> <browserCaps userAgentCacheKeyLength="256" /> <pages masterPageFile="~/XXXXXXny.master" styleSheetTheme="XXXXXXny" controlRenderingCompatibilityVersion="3.5" clientIDMode="AutoID"> <controls> <!-- Specify State Map Control--> <add tagPrefix="XXXXXX" tagName="StateMap" src="~/StateMap/MapNY.ascx" /> <add assembly="NWN.ControlLibrary" namespace="NWN.ControlLibrary" tagPrefix="NWN" /> <add tagPrefix="telerik" namespace="Telerik.Web.UI" assembly="Telerik.Web.UI" /> <add tagPrefix="ajaxToolkit" assembly="AjaxControlToolkit" namespace="AjaxControlToolkit" /> </controls> </pages> <httpRuntime targetFramework="4.5.1" useFullyQualifiedRedirectUrl="false" minFreeThreads="8" minLocalRequestFreeThreads="4" appRequestQueueLimit="100" maxRequestLength="8096" executionTimeout="300" /> <httpHandlers> <add verb="*" path="Reserved.ReportViewerWebControl.axd" type="Microsoft.Reporting.WebForms.HttpHandler, Microsoft.ReportViewer.WebForms, Version=11.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91" /> <add path="Telerik.RadUploadProgressHandler.ashx" type="Telerik.Web.UI.RadUploadProgressHandler" verb="*" validate="false" /> <add path="Telerik.Web.UI.WebResource.axd" type="Telerik.Web.UI.WebResource" verb="*" validate="false" /> <add path="ChartImage.axd" type="Telerik.Web.UI.ChartHttpHandler" verb="*" validate="false" /> <add path="Telerik.Web.UI.SpellCheckHandler.axd" type="Telerik.Web.UI.SpellCheckHandler" verb="*" validate="false" /> <add path="Telerik.Web.UI.DialogHandler.aspx" type="Telerik.Web.UI.DialogHandler" verb="*" validate="false" /> </httpHandlers> <httpModules> <add name="RadUploadModule" type="Telerik.Web.UI.RadUploadHttpModule" /> </httpModules> <customErrors mode="Off" defaultRedirect="~/Error/error.aspx"> <error statusCode="401" redirect="~/Error/401.aspx" /> </customErrors> <authentication mode="None"> </authentication> <trace enabled="false" requestLimit="10" pageOutput="true" traceMode="SortByTime" localOnly="true" /> <sessionState mode="InProc" stateConnectionString="tcpip=127.0.0.1:42424" sqlConnectionString="data source=127.0.0.1;Trusted_Connection=yes" cookieless="false" timeout="20" /> <globalization requestEncoding="utf-8" responseEncoding="utf-8" /> <healthMonitoring enabled="true"> <eventMappings> <!-- Log authentication failure events --> <add name="Auth Failure Audits" type="System.Web.Management.WebAuthenticationFailureAuditEvent" startEventCode="0" endEventCode="2147483647" /> <!-- Log authentication success events --> <add name="Auth Success Audits" type="System.Web.Management.WebAuthenticationSuccessAuditEvent" startEventCode="0" endEventCode="2147483647" /> <add name="Web Events" type="XXXXXX.Web.WebEvent" startEventCode="100004" endEventCode="100004" /> </eventMappings> <bufferModes> <add name="Critical Notification" maxBufferSize="100" maxFlushSize="20" urgentFlushThreshold="1" regularFlushInterval="Infinite" urgentFlushInterval="00:01:00" maxBufferThreads="1" /> </bufferModes> <providers> <clear /> <!-- Provide any customized SqlWebEventProvider information here (such as a different connection string name value --> <add connectionStringName="XXXXXX.ClassLibrary.My.MySettings.XXXXXX4ConnectionString" maxEventDetailsLength="1073741823" buffer="true" bufferMode="Critical Notification" name="SqlWebEventProvider" type="System.Web.Management.SqlWebEventProvider" /> </providers> <rules> <clear /> <add name="All Errors Default" eventName="All Errors" provider="SqlWebEventProvider" profile="Critical" /> <add name="Auth Failure Logging" eventName="Auth Failure Audits" provider="SqlWebEventProvider" profile="Critical" /> <add name="Auth Success Logging" eventName="Auth Success Audits" provider="SqlWebEventProvider" profile="Critical" /> <add name="Web Logging" eventName="Web Events" provider="SqlWebEventProvider" profile="Critical" /> <!--<add name="Application Events Default" eventName="Application Events" provider="SqlWebEventProvider" profile="Default" minInstances="1" maxLimit="Infinite" minInterval="00:00:00"/>--> </rules> </healthMonitoring> <webServices> <protocols> <remove name="Documentation" /> </protocols> </webServices> </system.web> </location> <!-- Prevent theme from being applied to site map --> <location path="SiteMap.aspx" allowOverride="false"> <system.web> <pages theme="" /> </system.web> </location> <location path="ws"> <system.web> <authorization> <deny users="?" /> </authorization> </system.web> </location> <system.webServer> <modules runAllManagedModulesForAllRequests="true"> <remove name="WebDAVModule" /> <remove name="RadUploadModule" /> <remove name="RequestFilter" /> <remove name="UrlRewrite" /> <remove name="Exception" /> <remove name="UsersOnline" /> <remove name="ClientDependencyModule" /> <remove name="DNNMembership" /> <remove name="Personalization" /> <remove name="Analytics" /> <remove name="MobileRedirect" /> <remove name="Services" /> <remove name="Detector" /> <add name="RadUploadModule" type="Telerik.Web.UI.RadUploadHttpModule" preCondition="integratedMode,runtimeVersionv2.0" /> </modules> <handlers> <remove name="ChartImage_axd" /> <remove name="Telerik_Web_UI_SpellCheckHandler_axd" /> <remove name="Telerik_Web_UI_DialogHandler_aspx" /> <remove name="Telerik_RadUploadProgressHandler_ashx" /> <remove name="Telerik_Web_UI_WebResource_axd" /> <remove name="ReportViewerWebControlHandler" /> <remove name="CombineScriptsHandler" /> <add name="Telerik_Web_UI_WebResource_axd" path="Telerik.Web.UI.WebResource.axd" type="Telerik.Web.UI.WebResource" verb="*" preCondition="integratedMode" /> <add name="ChartImage_axd" path="ChartImage.axd" type="Telerik.Web.UI.ChartHttpHandler" verb="*" preCondition="integratedMode" /> <add name="Telerik_Web_UI_SpellCheckHandler_axd" path="Telerik.Web.UI.SpellCheckHandler.axd" type="Telerik.Web.UI.SpellCheckHandler" verb="*" preCondition="integratedMode" /> <add name="Telerik_Web_UI_DialogHandler_aspx" path="Telerik.Web.UI.DialogHandler.aspx" type="Telerik.Web.UI.DialogHandler" verb="*" preCondition="integratedMode" /> <add name="Telerik_RadUploadProgressHandler_ashx" path="Telerik.RadUploadProgressHandler.ashx" type="Telerik.Web.UI.RadUploadProgressHandler" verb="*" preCondition="integratedMode" /> <add name="ReportViewerWebControlHandler" preCondition="integratedMode" verb="*" path="Reserved.ReportViewerWebControl.axd" type="Microsoft.Reporting.WebForms.HttpHandler, Microsoft.ReportViewer.WebForms, Version=11.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91" /> <add name="CombineScriptsHandler" verb="*" path="CombineScriptsHandler.axd" type="AjaxControlToolkit.CombineScriptsHandler, AjaxControlToolkit" /> <remove name="OPTIONSVerbHandler" /> <remove name="TRACEVerbHandler" /> <remove name="ExtensionlessUrlHandler-ISAPI-4.0_32bit" /> <remove name="ExtensionlessUrlHandler-ISAPI-4.0_64bit" /> <remove name="ExtensionlessUrlHandler-Integrated-4.0" /> <add name="ExtensionlessUrlHandler-ISAPI-4.0_32bit" path="*." verb="GET,HEAD,POST,DEBUG,PUT,DELETE,PATCH,OPTIONS" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersionv4.0,bitness32" responseBufferLimit="0" /> <add name="ExtensionlessUrlHandler-ISAPI-4.0_64bit" path="*." verb="GET,HEAD,POST,DEBUG,PUT,DELETE,PATCH,OPTIONS" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersionv4.0,bitness64" responseBufferLimit="0" /> <add name="ExtensionlessUrlHandler-Integrated-4.0" path="*." verb="GET,HEAD,POST,DEBUG,PUT,DELETE,PATCH,OPTIONS" type="System.Web.Handlers.TransferRequestHandler" preCondition="integratedMode,runtimeVersionv4.0" /> </handlers> <security> <requestFiltering> <requestLimits maxAllowedContentLength="8096000" /> </requestFiltering> </security> <validation validateIntegratedModeConfiguration="false" /> </system.webServer> <system.serviceModel> <bindings> <basicHttpBinding> <binding name="DataExchange2Soap" maxReceivedMessageSize="2147483647"> <security mode="Transport"> <transport clientCredentialType="None" /> </security> </binding> </basicHttpBinding> </bindings> <client> <endpoint address="XXXXXXXX" binding="basicHttpBinding" bindingConfiguration="DataExchange2Soap" contract="FileBoundWebService.DataExchange2Soap" name="DataExchange2Soap" /> </client> </system.serviceModel> <runtime> <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1"> <dependentAssembly> <assemblyIdentity name="Microsoft.Owin.Security" publicKeyToken="31bf3856ad364e35" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-3.0.1.0" newVersion="3.0.1.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Microsoft.Owin" publicKeyToken="31bf3856ad364e35" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-3.0.1.0" newVersion="3.0.1.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="WebGrease" publicKeyToken="31bf3856ad364e35" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-1.6.5135.21930" newVersion="1.6.5135.21930" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Microsoft.Owin.Security.OAuth" publicKeyToken="31bf3856ad364e35" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-3.0.1.0" newVersion="3.0.1.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-8.0.0.0" newVersion="8.0.0.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="Microsoft.Owin.Security.Jwt" publicKeyToken="31bf3856ad364e35" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-3.0.1.0" newVersion="3.0.1.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Web.Helpers" publicKeyToken="31bf3856ad364e35" /> <bindingRedirect oldVersion="1.0.0.0-3.0.0.0" newVersion="3.0.0.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Web.WebPages" publicKeyToken="31bf3856ad364e35" /> <bindingRedirect oldVersion="1.0.0.0-3.0.0.0" newVersion="3.0.0.0" /> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" /> <bindingRedirect oldVersion="1.0.0.0-5.2.2.0" newVersion="5.2.2.0" /> </dependentAssembly> </assemblyBinding> </runtime> <applicationSettings> <XXXXXX.Web.Properties.Settings> <setting name="XXXXXX_App_msu_WebPayment_msu_WebPayment" serializeAs="String"> <value></value> </setting> <setting name="XXXXXX_App_Branagh_ers" serializeAs="String"> <value></value> </setting> <setting name="XXXXXX_App_ReportExecution2005_ReportExecutionService" serializeAs="String"> <value>XXXXXX</value> </setting> </XXXXXX.Web.Properties.Settings> </applicationSettings> <entityFramework> <defaultConnectionFactory type="System.Data.Entity.Infrastructure.LocalDbConnectionFactory, EntityFramework"> <parameters> <parameter value="mssqllocaldb" /> </parameters> </defaultConnectionFactory> <providers> <provider invariantName="System.Data.SqlClient" type="System.Data.Entity.SqlServer.SqlProviderServices, EntityFramework.SqlServer" /> </providers> </entityFramework> <system.web> <compilation targetFramework="4.5.2" /> </system.web> </configuration> <!--ProjectGuid: 65B40E54-69A9-4677-8A87-68BFE70EAE5F-->
Here is the View for our Home page:
@inherits Umbraco.Web.Mvc.UmbracoTemplatePage @{ Layout = "Master.cshtml"; } <div class="content homepage"> <section class="banner"> <div class="banner-img"> <img src="@CurrentPage.bannerImage.Url" class="img-responsive" /> </div> <div class="banner-content-box"> <div class="container"> <h1> @Umbraco.Field("bannerMessage", removeParagraphTags: true) </h1> <div class="row"> <div class="col-md-offset-4 col-md-4 col-sm-offset-4 col-sm-4"> <a href="@CurrentPage.bannerButtonLink.Url" class="btn fourth-btn btn-lg btn-block"><i class="fa fa-fw fa-chevron-circle-right"></i>@Umbraco.Field("bannerButtonLabel")</a> </div> </div> </div> </div> </section> <section class="secondary-content"> <div class="container"> <div class="row"> <div class="col-md-6"> <div class="img-box"> <img src="@CurrentPage.image1.Url" class="img-responsive" /> </div> <p> @Umbraco.Field("description1", removeParagraphTags: true) </p> <div class="row"> <div class="col-md-offset-2 col-md-8"> <a href="@CurrentPage.button1Link.Url" class="btn btn-lg primary-btn btn-block"><i class="fa fa-wa fa-copy"></i>@Umbraco.Field("button1Label")</a> </div> </div> </div> <div class="col-md-6"> <div class="img-box"> <img src="@CurrentPage.image2.Url" class="img-responsive" /> </div> <p> @Umbraco.Field("description2", removeParagraphTags: true) </p> <div class="row"> <div class="col-md-offset-2 col-md-8"> <a href="@CurrentPage.button2Link.Url" class="btn btn-lg primary-btn btn-block"><i class="fa fa-wa fa-sign-in"></i>@Umbraco.Field("button2Label")</a> </div> </div> </div> </div> </div> </section> <section class="cta-area"> <div class="container-fluid"> <div class="col-md-offset-1 col-md-10"> <div class="row"> <div class="col-lg-10 col-md-9 col-sm-8"> <h2> @Umbraco.Field("featuredTitle") </h2> <p> @Umbraco.Field("featuredDescription", removeParagraphTags: true) </p> </div> <div class="col-lg-2 col-md-3 col-sm-4"> <a href="@CurrentPage.featuredButtonLink.Url" target="@CurrentPage.featuredButtonLink.Target" class="btn third-btn btn-lg btn-block"><i class="fa fa-fw fa-chevron-circle-right"></i>@Umbraco.Field("featuredbuttonLabel")</a> </div> </div> </div> </div> </section> </div>
Let me know if you need any other info.
I was able to solve this problem by adding the following to the child app web.config
<system.webServer> <modules> <remove name="UmbracoModule" /> <remove name="ImageProcessorModule" /> </modules>
Hopefully, this helps someone out down the road.
Marking as solved.
Missing Images When Configuring For Child Application
web.configof child app and the template markup part whereaspitelogo.pngexists?Here is the web.config:
Marking as solved.
