We recently switched our Umbraco site to HTTPS, and now we cannot create anything in the back office, as we receive this error in the console:
create
Load denied by X-Frame-Options:
When I change the value of "umbracoUseSSL" key from false to true in web.config, I cannot login the back office due to too many redirection error.
Is there any other way to solve this problem?
Regards.
I have a lot of tips about https in my blog post here: https://cultiv.nl/blog/so-you-want-to-secure-your-umbraco-site/
For the first error you need to allow some iframes for certain locations (umbraco path).
The redirects problem doesn't ring a bell directly but maybe the blog post will help you find the magical balance.
Hi Sebastiaan,
Actually your article was the first thing I checked via Google search and made the 'umbracoUseSSL' change accordingly.
For the first error you need to allow some iframes for certain locations (Umbraco path).
I will read further about this suggestion now.
This was the solution for my problem.
So, I changed the value of "umbracoUseSSL" key back to false, and added the following section to my web.config:
false
<location path="umbraco"> <system.webServer> <urlCompression doStaticCompression="false" doDynamicCompression="false" dynamicCompressionBeforeCache="false" /> <httpProtocol> <customHeaders> <remove name="X-Frame-Options" /> <add name="X-Frame-Options" value="SAMEORIGIN" /> <remove name="Content-Security-Policy" /> <add name="Content-Security-Policy" value="default-src 'self' www.gravatar.com player.vimeo.com *.vimeocdn.com packages.umbraco.org our.umbraco.org;script-src 'self' 'unsafe-inline' 'unsafe-eval';style-src 'self' 'unsafe-inline';img-src 'self' data: www.gravatar.com umbraco.tv;font-src 'self';" /> </customHeaders> </httpProtocol> </system.webServer> </location>
Problem solved! Thank you very much Sebastiaan..
Load denied by X-Frame-Options: <URL> does not permit framing.
createanything in the back office, as we receive this error in the console:Load denied by X-Frame-Options:
too many redirectionerror.Is there any other way to solve this problem?
Regards.
Hi Sebastiaan,
false, and added the following section to my web.config:Problem solved! Thank you very much Sebastiaan..
