  • Thomas 319 posts 606 karma points c-trib
    Sep 26, 2017 @ 14:12
    Thomas
    Best Practice for doctypes and menu
    Hey,
    As showen in the image I have 4 menus in the header. Right now I have 4 diffrent doctypes so I can control where the menu links should show up in the right menu.
    But the problem is that I'm going to have more then one type of doctype in each menu..
    What would be best practice for displaying the nodes in the right menus? enter image description here
    Hope it makes sense :)
  • Nigel Wilson 945 posts 2077 karma points
    Sep 26, 2017 @ 20:16
    Nigel Wilson
    101
    Hi Thomas
    One possible option is to have 4 multi node pickers on the home page and select the menu items there. Then you can target the specific node picker and output the nodes.
    Another option is to have checkboxes on each content page for each menu and tick the ones for where the menu should appear.
    Personally the first option feels better as it's far easier to see and manage.
    Hope this helps.
    Cheers, Nigel
    Sep 27, 2017 @ 14:12
    Thomas
    I went with to first solution! Worked like a charm! Thanks!
