  • Damon 217 posts 288 karma points
    Oct 04, 2017 @ 09:39
    Damon
    Question on routing and using two homepages
    I have a Umbraco 7 site with two homepages and each has subpages.
    The routing does not seem to take into account the two homepages.
    e.g. If I want to navigate to subpage1 in home1,
    then home1/subpage1 returns page not found.
    If I want to navigate to subpage2 in home2
    then home2/subpage2 returns page not found. But /home1 directly and /home2 directly work.
    Why is the top homepage not taken into account here? I could do with this to set up the two menu correctly,
    Thanks a lot!
    Oct 04, 2017 @ 09:40
    Alex Skrypnyk
    101
    Hi Damon
    Go to manage hostnames in Umbraco(press right button on the each root node) and set "home1/subpage1" host for the first root node and "home2/subpage2" for the second one.
    It should solve the issue.
    Alex
    Oct 04, 2017 @ 21:04
    Alex Skrypnyk
    Hi Damon
    Did you solve the issue? Can you share with the community?
    Alex
