  • Tim Laughlin 10 posts 30 karma points
    Oct 04, 2017 @ 15:04
    Tim Laughlin
    Umbraco 7.6.5 to 7.7.2 NuGet Upgrade Issue
    Getting the following exceptions when trying to login after the NuGet upgrade. It is trying to login to "AuthorizeUpgrade".
    2017-10-04 09:59:05,949 [P57808/D4/T12] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Exception (556203e9).
    System.Data.SqlClient.SqlException (0x80131904): Invalid object name 'umbracoUser2UserGroup'.
       at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
       at System.Data.SqlClient.SqlDataReader.get_MetaData()
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
       at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>c__DisplayClass5_0.<ExecuteReaderWithRetry>b__0()
       at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func)
       at Umbraco.Core.Persistence.Database.<Query>d__115`1.MoveNext()
    ClientConnectionId:d217087c-7079-4218-9491-d61b768d926f
    Error Number:208,State:1,Class:16
     2017-10-04 09:59:05,974 [P57808/D4/T12] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Exception (b4fa670e).
     2017-10-04 09:59:05,995 [P57808/D4/T12] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Exception (3138fb82).
     2017-10-04 09:59:06,021 [P57808/D4/T12] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Exception (df436810).
    System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'createDate'.
    Invalid column name 'updateDate'.
       at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>c__DisplayClass2_0.<ExecuteNonQueryWithRetry>b__0()
       at Umbraco.Core.Persistence.Database.Update(String tableName, String primaryKeyName, Object poco, Object primaryKeyValue, IEnumerable`1 columns)
    Error Number:207,State:1,Class:16
     2017-10-04 09:59:06,022 [P57808/D4/T12] WARN  Umbraco.Core.Services.UserService - An error occurred attempting to save a user instance during upgrade, normally this warning can be ignored. Exception: System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'createDate'.
       at Umbraco.Core.Persistence.Database.Update(Object poco, Object primaryKeyValue, IEnumerable`1 columns)
       at Umbraco.Core.Persistence.Repositories.UserRepository.PersistUpdatedItem(IUser entity)
       at Umbraco.Core.Cache.DefaultRepositoryCachePolicy`2.Update(TEntity entity, Action`1 persistUpdated)
       at Umbraco.Core.Persistence.UnitOfWork.ScopeUnitOfWork.Commit(Action`1 transactionCompleting)
       at Umbraco.Core.Services.UserService.Save(IUser entity, Boolean raiseEvents)
     2017-10-04 09:59:06,024 [P57808/D4/T12] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Exception (ea1e7457).
     2017-10-04 09:59:06,046 [P57808/D4/T12] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Exception (22dbf900).
    Oct 04, 2017 @ 16:26
    Sebastiaan Janssen
    Can you see if you recognize some of the problems in this issue please? http://issues.umbraco.org/issue/U4-10472
    If you're not using MySQL, I'm really eager to get my hands on a SQL server database that exhibits this problem. My email address and some instructions to send me a database are in the issue.
