  • Jason Elkin 38 posts 351 karma points MVP 3x c-trib
    Oct 10, 2017 @ 09:14
    Jason Elkin
    Azure SQL "index recommendation"
    I have a number of Umbraco sites running in Azure with Azure SQL and occasionally I get an email come through from the Azure SQL Database Advisor with the following suggestion:
    Target object: [dbo].[cmsDocument]
    Recommended action: CreateIndex
    Indexed columns: [published], [nodeId]
    Estimated Index Impact: HIGH IMPACT
    Is it safe to do this? Would this result in a genuine performance gain?
    I'm no DBA, and not very familiar with Umbraco's database design so I'm not sure of the implications. Most importantly I don't want to break the upgrade path.
    Any help would be great.
    Also, if this is a genuine performance gain then I presume it would make sense to include this in Umbraco itself?
