  • Anja 13 posts 118 karma points
    Oct 12, 2017 @ 09:36
    Anja
    Workingh with Solutions
    I am starting woth Umbraco and up to now I just used the backend, which will not suffice anymore, I will have to work in VisualStudio using the solution. My problem: I started by unpacking the zip and running it in WebMatrix. What kind of preparations are necessary for the change? (I am familiar with solutionstructures in VisualStudio).
    Regards
    Anja
    Oct 12, 2017 @ 09:44
    Alex Skrypnyk
    Hi Anja
    Are you working with the existing solution? Or the new one?
    The easiest way to start new project is to create new project in VS and run nuget command "Install-Package UmbracoCms -Version 7.7.2"
    Alex
    Oct 12, 2017 @ 12:41
    Anja
    Hi Alex,
    thanks, that was the missing info!
    Another thing... I wanted to try Umbraco Forms, installed, created a form... but can't select it in the frontend.... the fieldwhere I should be able to pick it is non-editable. Do I need a license to enable it?
    Regards
    Anja
    Oct 13, 2017 @ 14:45
    Alex Skrypnyk
    Hi Anja
    How do you try to select it? Via insert macro to Rich Text Editor?
    Alex
  • John Bergman 483 posts 1132 karma points
    Oct 13, 2017 @ 04:18
    John Bergman
    Install the nugget package of forms as well... make sure it is the latest version because there was a compatibility issue (really an install issue)
