  • burgi 16 posts 98 karma points
    Oct 23, 2017 @ 14:53
    burgi
    Maintenance Mode
    I've been doing a lot of reading throughout the day and I am really confused with how Umbraco does maintenance pages.
    The prevailing advice appears to be use app_offline.htm in the root folder. While this works for bulk file uploads it doesn't really work if I want to amend the content or perform other functionality checks before releasing to the wild.
    I've tried to follow the guide here but it doesn't appear to work for IIS 8.5.
    What is the best way to put Umbraco into maintenance mode while retaining access to the CMS for certain users?
  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    Oct 23, 2017 @ 16:15
    Kevin Jump
    Very timely (but also very new) - I've just now released a maintenance mode package (https://our.umbraco.org/projects/backoffice-extensions/maintenance-manager/) - Which lets you switch your site into maintenance mode via the back office.
    but
    The IIS Rewrite stuff will work on IIS8.5 but i think you need to install the URL Rewrite module as its not installed by default on older windows server builds. https://www.iis.net/downloads/microsoft/url-rewrite
  • Gerhard Grossberger 55 posts 179 karma points
    Oct 14, 2022 @ 10:39
    Gerhard Grossberger
    I already posted this in a separate question here:
    https://our.umbraco.com/forum/using-umbraco-and-getting-started/110150-maintenance-manager-rendermvccontroller
    we wanted to add Maintenance Manager to one of our older pages in Umbraco v8. It turns out, it doesn´t work with pages that extend RenderMvcController. Is this a known issue, and is there a workaround? Best, Gerhard
    any ideas?
