Or, if you have too many pages, and are moving from an old site to a new one, use ContentFinder/URL Provider, especially if you can put match your old pages to your new ones (maybe in a lookup table).
Perhaps you need both an URL rewrite and a ContentFinder.
The ContentFinder could have a global hashtable to match the two fields up, so you wouldn't have to do that on every page load, and would strip out the querystring.
UmbracoUrlAlias scenatio with .ext and querystring
I've got a scenario using the UmbracoUrlAlias that I can't wrap my head around. Or rather, I can't figure out how it's supposed to work.
Long story short, I want to redirect all inbound traffic from: www.example.com/_pages.asp?page=100&ID=10&NAME=whatever (A)
to: www.example.com/somewhere (B)
I want to use UmbracoUrlAlias so that our editors will be able to map _pages.asp to /somepage.
As far as I can tell there is two problems with that.
1) ISAPI will hijack the request going to .asp, I guess I simply can uninstall it.
2) The receiving page will have the querystring in the request.
So. How would I be able to use UmbracoUrlAlias to map A to B? Is it even possible?
If not, what would you suggest as a better alternative?
How about trying a URL Rewrite?
Well. The idea is to make the editors own that configuration. So, no, that's unfortunately not an option.
Also, there isn't a structure to the rewrites. A batch would be nice, but impossible :(
