I think I'm somehow missing a trick with this, but I can't quite put my finger on what it is, and was hoping someone could point me in the right direction.
On one of my Umbraco pages, I have a login form, which submits post data to a controller, which then logs the user in using:
After this point, "authenticated" gets set to true, and the member's "last login date" gets updated with the current timestamp.
However.. then I assumed for detecting that the user was logged in, I could use one of the following:
var test_01 = Members.GetCurrentLoginStatus();
var test_02 = Members.CurrentUserName;
var test_03 = Members.GetCurrentMember();
var test_04 = Members.GetCurrentMemberId();
var test_05 = Members.IsLoggedIn();
but every single one of these fires as if there is no logged in user.
Little confused as to where I'm going wrong, can anyone lend a hand? :)
Ever seen a case where every "logged in" property is false? :p
First time I've come across it, and I don't remember having to do any additional config / setup with the other sites I had membership on.
Just in case anyone else runs into this issue, the cause was down to an issue with my Forms Authentication setup. I had to reconfigure my settings in web.config to resolve.
Membership Provider Login Detection Issue
Try
Yeah, I'd checked the properties inside the LoginStatusModel, and unfortunately, that one is false as well :(
I've also seen cases where IsLoggedIn is true, but GetCurrentMemberId returns -1.
Ever seen a case where every "logged in" property is false? :p First time I've come across it, and I don't remember having to do any additional config / setup with the other sites I had membership on.
Anyone got any ideas? :)
