  • Sandy Drake 3 posts 73 karma points
    Nov 13, 2017 @ 09:37
    Sandy Drake
    Problem running Umbraco on server
    I have just started working with Umbraco and things were going great while I was running the Umbraco project directly from Visual Studio using IIS Express. However I'm having an awful time trying to get things running on a server.
    To keep things simple I have created an empty installation of Umbraco which I have just moved to a server. It seemed to be fine and when I visited the URL I got the default Umbraco page. I logged in to Umbraco and created a homepage documenttype, template and added some content. (I followed the tutorial https://our.umbraco.org/documentation/tutorials/creating-basic-site/Creating-Your-First-Template-and-Content-Node just to be sure I was doing everything correctly).
    Save and publish seemed to work fine and when I click Preview a new page opens for the preview but just hangs there with the timer circle going round and round.
    The log file in app_data doesn't tell me anything more than the page was published.
    Any suggestions? Thanks in advance.
    Nov 13, 2017 @ 09:48
    Alex Skrypnyk
    Hi Sandy
    It's hard to define what is the problem, did you transfer all templates to the server? If you publish the page and open it in the browser is it working?
    Alex
    Nov 13, 2017 @ 10:00
    Sandy Drake
    Hi Alex
    Are you asking about the templates as created under settings? If so there should only be one and it was created on the server so didn't require transferring. Or are there other templates I should know about? Sorry I'm a total newbie...
    The published page is not working in the browser and now if I try and visit the site url (where previously there was the default Umbraco page) I get an error - "this site can't be reached".
    Sandy
  • Craig Mayers 164 posts 508 karma points
    Nov 13, 2017 @ 10:37
    Craig Mayers
    Hi Sandy,
    I think Alex means all the Umbraco files that come with each install.
    Have you checked the permissions on the server? See the following link: https://our.umbraco.org/documentation/getting-started/setup/install/permissions
    Also, what version are you running?
    Craig
    Nov 13, 2017 @ 11:49
    Sandy Drake
    Hi Craig
    Thanks for your suggestion, I am waiting for my hosting company to come back to me regarding the permissions on the server.
    I'm running Umbraco v7.7.4.
    As for the files that come with each install - I published the solution from Visual Studio, and then copied the published website over to the server. Should I be copying the entire VS project over to the server rather than the published website?
    Sandy
