  • ibrahim Nada 12 posts 102 karma points
    Nov 19, 2017 @ 14:50
    ibrahim Nada
    Umbraco and angular
    im very good with umbraco and im planning to take it to the next level witch is extending umbraco and make my one custom datatype and embed my own business logic. in order to achieve that i need to learn angular im filmier with angular but i dont wanna learn in-depth angular one then umbraco change there orientation to angular 2 so, what do u recommend me to learn in-depth angular one or angular 2 ?
  • Ben Palmer 180 posts 866 karma points c-trib
    Nov 19, 2017 @ 14:54
    Ben Palmer
    3
    Angular 2 in Umbraco is some way off I believe. Even Umbraco 8 will still be on Angular 1 so if it's primarily for extending Umbraco - I'd go for that.
    Having said that, I've found you don't need to be an Angular expert to extend Umbraco - chances are you'll probably not need to be an expert (I'm certainly not), unless you're planning something really big.
