  • mhasnik 4 posts 71 karma points
    Nov 29, 2017 @ 17:54
    mhasnik
    Angular 5 (cli generated) and Umbraco 7 as backend
    I'm struggling to implement the following solution:
    I want Umbraco to work as a backend where I can create content in the backoffice and serve it through UmbracoWebApi to Angular 5 app which will handle the display.
    The way I imagined it will work is when going to mysite.com/umbraco[...] umbraco routing kicks in so I can access backoffice and web api controllers, but apart from that I want angular to handle the routing
    I already spent two days to find a solution, is it even possible to do that?
  • Dave 15 posts 89 karma points
    Jan 31, 2018 @ 14:07
    Dave
    Hey,
    Did you ever get this working?
    I was looking at using a "headless" umbraco solution with Angular 5 and I think I might know what you are looking for.
    Cheers, Dave
