  • Stephanie Bouzounis 2 posts 72 karma points
    Nov 29, 2017 @ 19:59
    Stephanie Bouzounis
    Editing a Product's Attributes in Product Management
    We had our site built in Umbraco by an outside agency that we do not currently work with. That agency created certain products and loaded attributes into Umbraco. I need to edit those products, however, when I go to Product Management and click on a product, I can see everything but the listed attributes even though they are visible on the site. Is there a way around this? If so, please let me know!
    Cheers & thanks! Stephanie
  • David Peck 690 posts 1896 karma points c-trib
    Nov 29, 2017 @ 20:58
    David Peck
    Hi Stephanie,
    Are you using an ecommerce package like uCommerce, TeaCommerce or Merchello do you know?
    This doesn't sound like something that Umbraco comes with as standard. If it isn't a specific package then you'll like require a developer to look in to it for you.
    Best,
    David
    Nov 29, 2017 @ 21:02
    Stephanie Bouzounis
    David,
    We're working with a new agency who's a Gold Partner, and I asked them if there was a way around it. I don't know if it our Umbraco came as a package or not, but I think it uCommerce was mentioned by my boss at some point.
    • Stephanie
    Nov 29, 2017 @ 22:25
    David Peck
    I'd suggest reposting your query in the uCommerce forum then. You stand a better chance of getting a decent response there. I've never used it unfortunately.
