  • Benoit Cornette 29 posts 169 karma points
    Dec 06, 2017 @ 07:35
    Benoit Cornette
    Edit "Created by" in SQL CE
    Is it possible to change the "created by" value in SQL CE?
    Kind regards,
    Benoit
    Dec 06, 2017 @ 09:10
    Alex Skrypnyk
    Hi Benoit
    Do you want to change created by field of node?
    I think it's not possible from backend, try to do it directly in database.
    SQLCE is similar database as MSSQL - just connect to it with SQLCE Toolbox and edit needed field
    Alex
