I would like to make a multi-lingual site, but not using the umbraco's built in support, because I dont want to make separate content for each. I would like to make one content, and change the language on-page. How can I do this?
If you don’t want to use the Umbraco multi language feature and you only want to create one node then I’d suggest some sort of plugin which sits on the view.
Multi-lingual site
I’ve used this before: https://www.microsoft.com/Web/solutions/mstranslator.aspx
Have you looked at Vorto? I understand that's not quite what you're asking for.
