  • Alistair Jenkins 92 posts 315 karma points
    Jan 05, 2018 @ 11:54
    Alistair Jenkins
    Incorrect connection string for local MSSQL database
    I am trying to set up a local instance of Umbraco for development purposes and I'm having trouble getting the connection string right for the SQL database.
    I have an MS SQL database installed using MS SQL Server 2017 (Developer Edition) on a PC called CVN-AL. It uses Windows Authentication. I've tried various connection strings like:
    <add name="umbracoDbDSN" connectionString="Server=CVN-AL;Database=cvnsitesdb;User ID=CVN\alistair;Password=********" providerName="System.Data.SqlClient" />
    with no success. Can anyone tell me what the right way to phrase this would be?
    Jan 05, 2018 @ 14:08
    Alex Skrypnyk
    Hi Alistair
    Can you connect to database with mssql management studio and this connection string?
    Is "User ID=CVN\alistair" right user?
    Alex
    Jan 05, 2018 @ 15:11
    Alistair Jenkins
    Hi Alex,
    Thanks for replying. I eventually found a solution on another post. I replaced the string with this one:
    <add name="umbracoDbDSN" connectionString="Server=CVN-AL;Database=cvnsitesdb;Integrated Security=True" providerName="System.Data.SqlClient" />
    which worked fine.
    Cheers, Alistair
    Jan 05, 2018 @ 15:38
    Alex Skrypnyk
    Hi Alistair
    Glad that you found a solution.
    Alex
