  • Owain Williams 482 posts 1414 karma points MVP 8x c-trib
    Jan 06, 2018 @ 22:03
    Owain Williams
    Showing X number of posts via Controller
    Hi, I've created a controller which is used to display a title of the blog on the homepage. Just now I do this like so :
    List<BlogPostListModel> model = new List<BlogPostListModel>();
    IPublishedContent blog = CurrentPage.AncestorOrSelf(1).DescendantsOrSelf().Where(x => x.DocumentTypeAlias == "blog").FirstOrDefault();
    foreach (IPublishedContent blogpost in blog.Children)
    model.Add(new BlogPostListModel(blogpost.Name));
    return PartialView("~/path/to/partial", model);
    This is fine except, it displays all the blog titles, what I want to do is check to see if the number of blogs within the CMS is more than the number wanted from the backoffice. In the backoffice I have a slider which allows the user to pick how many blogs to show on the homepage. So if I have 10 blogs, I only want to show the 3 latest.
    I was thinking something like
    var numToShow = blog.GetPropertyValue<int>("howManyPostsShouldBeShown");
    if (blog.Children.Count() > numToShow)
    would work but my issue now is, how to I only show the number of blogs I want within the If statement?
    Hope that makes sense, been scratching my head all evening.
    O.
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Jan 06, 2018 @ 22:17
    Nik
    Hey Owain,
    You can use Linq to do this really quickly.
    foreach (IPublishedContent blogpost in blog.Children.Take(numToShow))
    (You might to do Children.Skip(0).Take(numberToShow) I'm not 100% on that though.)
    That will take upto the number you've selected to show.
    So, if blog.Children.Count() = 5 and numToShow = 6, it will only take 5. And if numToShow = 4 it will only take 4.
    Nik
    Jan 07, 2018 @ 13:48
    Owain Williams
    Oh boy, I was close :)
            foreach (IPublishedContent blogPost in blog.Children)
                    model.Add(new BlogPostListModel(blogPost.Name, blogPost.GetPropertyValue<string>("pageTitle"), blog.GetPropertyValue<int>("howManyPostsShouldBeShown")));
    Just didn't have the .Take.
    Thanks everyone!!
  • Matthew Wise 271 posts 1373 karma points MVP 6x c-trib
    Jan 06, 2018 @ 23:55
    Matthew Wise
    Yeah, take a look at Take in Linq like Nik said.
    Although I would say you may want to use examine / xpath for the query as Descendants calls are slower.
    Have a look at these great slides from dawoe (I can't remember his actual name :'( )
    https://www.slideshare.net/dawoe/umbraco-duugfest-17-the-need-for-speed
  • OleP 67 posts 276 karma points
    Jan 07, 2018 @ 10:26
    OleP
    Thanks for the share. I rely heavily on the ContentService, so this might be a field where I can improve. But I'd say it depends on how many published items you've got. If OP only got a few houndred items, Children/Descendants is fine.
    Jan 07, 2018 @ 10:30
    Matthew Wise
    2
    The content service should not be used for front end requests, it makes database calls instead of calls to the Umbraco cache.
    The code above uses the cache as well.
