I am building a simple Grid control and I wondered if it was possible to make any of the fields "Required" ?
If it is possible does anyone have any sample code to put validation into the grid?
The trick is to give the element (field) a unique ID, and you can then check whether that element has some of the classes added by Angular during validation.
Grid control validation
I am building a simple Grid control and I wondered if it was possible to make any of the fields "Required" ? If it is possible does anyone have any sample code to put validation into the grid?
Jon
Hi Jonathan,
Umbraco uses Angular for validation, so the fields will be required if you add a
requiredattribute - eg:Alternatively you can use
ng-requiredinstead to use a condition - if a setting telling whether the field you in fact be required.That is great - how do you set a Required warning next to the correct field in the Grid?
A required field will get a red border if you hit Save, and the field doesn't have a value. Is that sufficient?
Otherwise it gets a bit more complex. I did this for one of my packages - you can see that here:
https://github.com/skybrud/Skybrud.ImagePicker/blob/master/src/Skybrud.ImagePicker/App_Plugins/Skybrud.ImagePicker/Directives/ImagePicker.js#L23
Fantastic - thanks again for all your help
