I've run into an odd error with the backoffice. The Examine indexes were all showing "The index cannot be read and will need to be rebuilt" in the developer tab. There was an issue with the indexing, so I fixed that and rebuilt the indexes. The message was still there. I even deleted the index folders and had the site regenerate them from scratch, but it's still giving an error message. The files are being generated and the searches appear to work fine, so this looks like a reporting error. Has anyone else run into this?
Problem with Examine Backoffice in 7.5.11
Hi Andrew Watt,
Can you please update the client dependency version in the
/Config/ClientDependency.config
And restart the website by touching the
Web.config
file.It should remove the Error :)
Good luck
That didn't seem to change anything. Thanks though.
