Flexible load balancing publishing takes too long to update content on front-end servers
Hey everyone, I have recently upgraded from 7.2.6 to 7.5.14 and set up a flexible load balancing. The published content is updating but it takes way too long to update on front-end servers. Just wanted to ask here if anyone have any recommendations or experienced similar behavior when using flexible load balancing as explained in Steps section below:
Setup:
Umbraco 7.5.14
1 master scheduling server
2 slave front-end servers, No file replication, I have followed flexible load balancing guide and configured an explicit master scheduling server (https://our.umbraco.org/documentation/getting-started/setup/server-setup/load-balancing/flexible-advanced#explicit-master-scheduling-server)
I have left the umbracoApplicationUrl empty
I’m not on Azure
There are no entries added to umbracoServer table
I can access the two front-end servers separately to check for content change
Steps:
Publish an item on the CMS master server
Instruction is added to cache instructions table immediately
About a 30-40 seconds later the last synced.txt file id is updated on the master server
About 3 minutes later, on one of the slave servers the Umbraco.Web.Scheduling.KeepAlive kicks in shortly followed by the DatabaseServerMessenger - Syncing from database... and the lastsynced id is updated.
About 2 minutes later the DatabaseServerMessenger - Syncing from database... kicks in on the second front-end server and the last synced id is updated to the latest one.
I can confirm that the master and slave servers are set correctly by a log message on slave servers - Umbraco.Web.Scheduling.ScheduledPublishing - Does not run on slave servers.
Setup:
Steps:
Thanks a lot!
