I "think" you can do a null check on what is returned from TypedMedia. If the id doesn't exist then I believe it returns null.
Personally, if I was taking that approach on the Home node (your site's root node). I would have a media picker to pick the media item to use. Then get the value from there. It is bad practice to hard code content/media id's as it is possible for them to be deleted.
Check if media exist in razor
I have the following logic I am using to load a favicon in my master template...
Is there a strong type way in wrapping this into a condition that checks if 1284 exist, then execute?
The method
TypedMediawill return an instance ofIPublishedContent- you can check whether this is null like this:Hi Blackhawk,
You'd possibly also want some logic to check that the media item actually still exists on the disk. This is a nice little blog post on how to do that: https://codeshare.co.uk/blog/how-to-get-the-file-path-of-a-media-item-in-umbraco/
Nik
Thanks for the tip on leveraging media picker rather than hard coding Id's. Much appreciated on that insight! I'm gonna give this approach a shot.
