I've upgraded to 7.8.0 using NuGet and now the new "info" tab doesn't display the translations, everything is [general_....], see:
https://i.imgur.com/UUcjA4Y.png
How can I resolve this?
Hi Umbrakko
Do you have some console errors?
Upgrade process was successful?
/Alex
Yes, the upgrade was successful. No console errors either.
Check, please, users section, your user has to have right culture in the backoffice.
It's set to en-US, I already modified this to another language (uk and another one) and it's the same issue.
Some of the strings in the section work: https://i.imgur.com/kZOjYyQ.png
I found a fix, in this new 7.8.0 version the language is en_us.xml , whereas the previous version used us.xml. I've now copied en_us.xml to us.xml and it's working.
en_us.xml
us.xml
I think something ain't right with the 7.8 release then :)
Thanks Umbrakko that did the trick. + web.config touch to restart the app.
Glad that the topic is solved, have a great day!
general_info etc in 7.8.0
Hi Umbrakko
/Alex
en_us.xml, whereas the previous version usedus.xml. I've now copieden_us.xmltous.xmland it's working.I think something ain't right with the 7.8 release then :)
