  • Mike Cave 24 posts 162 karma points
    Feb 08, 2018 @ 11:09
    Mike Cave
    Add Archetype to my project
    Hi guys,
    I have an inherited project which uses umbraco. The .Net project is not runnable and does not have a .prj file or a .sln. (I know, right).
    I need to add Archetype to my project to allow me to have some repeatable content on a page.
    I cant use Nuget to install Archetype as it fails with :
    Install-Package : Project 'Default' is not found. At line:1 char:16 + Install-Package <<<< Archetype + CategoryInfo : ObjectNotFound: (Default:String) [Install-Package], ItemNotFoundException + FullyQualifiedErrorId : NuGetProjectNotFound,NuGet.PackageManagement.PowerShellCmdlets.InstallPackageCommand
    I have downloaded the zip file and extracted the files.
    My question is, where do I install the Archetype Dll and where do the other files (.css, .html etc) go in my project? And then how do I add it in to Umbraco so I can use the new tool?
    Any help gratefully received. thanks
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Feb 08, 2018 @ 11:55
    Dan Diplo
    101
    You can also add Archetype as an Umbraco Package (which you can install from the Developer area of the Umbraco backend). You can get it from:
    https://our.umbraco.org/projects/backoffice-extensions/archetype/
    However, if you are using a recent version of Umbraco then it will come with Nested Content (as a datatype) which basically does the same thing as Archetype.
    If you are using an older version it can be downloaded as a stand-alone package, too:
    https://our.umbraco.org/projects/backoffice-extensions/nested-content/
    Documentation: https://github.com/umco/umbraco-nested-content/blob/develop/docs/developers-guide.md
    Feb 08, 2018 @ 12:00
    Mike Cave
    Thanks Dan, I'm using Umbraco 7.2.8, I don't know how new that is :-) I will look for nested content first.
    thanks for your help (again), you are a great help.
    Mike.
    Feb 09, 2018 @ 12:04
    Mike Cave
    Hi Dan,
    thanks that worked a treat. Its definitely one step forward two steps back though!
    Appreciate your help
    Mike
