  • Jacek 1 post 71 karma points
    Feb 13, 2018 @ 12:07
    Jacek
    Umbraco search Lucene randomly fails to work with some indexes
    We've got an umbraco site working in the AZURE production environment and we use Lucene to search for the big amount of data on the site. We create indexes (rebuild and update them) and the thing is the Lucene just randomly fails to look for some of them just sometimes... The only piece of log I can give is:
    2017-11-10 13:50:12,710 [P11168/D2/T10] WARN Umbraco.Web.PublishedCache.XmlPublishedCache.PublishedMediaCache - Could not retrieve media 39687 from Examine index, reverting to looking up media via legacy library.GetMedia method 2017-11-10 13:50:45,988 [P11168/D2/T89] WARN Umbraco.Web.Mvc.RenderMvcController - No physical template file was found for template Web/So/Event 2017-11-10 13:51:13,797 [P11168/D2/T67] INFO umbraco.content - Save Xml to file... 2017-11-10 13:51:14,219 [P11168/D2/T46] INFO umbraco.content - Saved Xml to file. 2017-11-10 13:51:21,991 [P11168/D2/T166] ERROR eBiletPortal.Search.CustomContentIndexer - Błąd indeksowania elementu: 39787 System.NullReferenceException: Object reference not set to an instance of an object. at Portal.Search.CustomContentIndexer.CustomContentIndexer_DocumentWriting(Object sender, DocumentWritingEventArgs e) in C:\TeamCity\buildAgent\work\c8839ecee33fc77e\src\Portal\Portal.Search\CustomContentIndexer.cs:line 54
    Did anyone have met with something similar?
    Feb 14, 2018 @ 16:28
    Alex Skrypnyk
    Hi Jacek
    Are you using library.GetMedia method?
    Can you share CustomContentIndexer.cs class?
    /Alex
