Hi there
When I am using a partial view:
@inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var selection = Model.Content.Site().Children.Where("umbracoFooterNav"); }
Umbraco returns in Visual Studio
This method uses dynamics which will be removed in future versions, use strongly typed syntax instead''
But I was under the impression that Model.Content was the strongly typed. What is wrong with my partial view?
Hi Elitenet,
I'm not sure, but I think it is your use of Children and you use of Where that is resulting in the dynamic result.
Model.content.Site(), is as far as I know returning an strongly typed implementation.
Try changing Children to Children() and Where to a full LINQ expression.
Nik
I can see that Nik was faster than me, but here goes anyways:
Your view itself is actually fine. It is the Where method and the way that you use it that gives a warning, as it uses dynamics internally. Your code could be changed to:
Where
@inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var selection = Model.Content.Site().Children.Where(x => x.DocumentTypeAlias == "umbracoFooterNav"); }
Then you'll keep using the strongly typed models, and the warning is gone ;)
Okay thanks.
I think I have mixed it up during an recode from @Currentpage to @Model. Makes sense that it originally was CurrentPage.
Funny that the warning wasnt there originally. I think the warning came when I later upgraded whole umbraco code to 7.7.9.
Well that's something to look out for when projects are going to be recoded to Strongly Types.
thanks again :-)
Partial View and Strongly Typed
Hi there
Hi Elitenet,
Nik
Wheremethod and the way that you use it that gives a warning, as it uses dynamics internally. Your code could be changed to:Then you'll keep using the strongly typed models, and the warning is gone ;)
Okay thanks.
thanks again :-)
