Is Umbraco overriding my session, do I need to do something special to work with session values in Umbraco?
Hi I am having a weird problem, and am hoping someone can shed some light on it.
I am creating my first Umbraco application, I get the users location and determine the closest store location for them. I need to set this value in the session.
I am getting the location and storing it in the session, but then when I go to access it, the session variable is gone.
In My layout:
var locID = 1;
$(document).ready(function () {
$.ajax({
url: '@Url.Action("GetLocation", "Home", null)',
data: { lon: longitude, lat: latitude },
async: false,
success: function (result) {
console.log(result);
var parsedResult = JSON.parse(result);
locID = parsedResult.LocationID;
$.ajax({
url: '@Url.Action("SetLocationInSession", "Home", null)',
data: { locationID: locID },
async: false,
success: function () {
console.log("Location set in session");
error: function (data) {
console.log(data);
$(".search").click(function () {
$.ajax({
url: '@Url.Action("GetLocationInSession", "Home", null)',
data: { key: "location" },
async: false,
$("#locationID").val(locID);
console.log(data);
The set session seems to work fine. In my controller (a surfaceController being rendered as a partial view on an Umbraco page if that matters) looks like this:
public ActionResult GetLocation(double lon, double lat)
GeoHelper geoHelper = new GeoHelper();
Context _db = new Context();
var locations = _db.Locations.ToList();
var location = geoHelper.GetClosestLocation(lat, lon, locations);
LocationViewModel closest = new LocationViewModel();
closest.LocationID = location.LocationID;
closest.Name = location.Name;
closest.Longitude = location.Longitude;
closest.Latitude = location.Latitude;
JavaScriptSerializer javaScriptSerializer = new JavaScriptSerializer();
string result = javaScriptSerializer.Serialize(closest);
return Json(result, JsonRequestBehavior.AllowGet);
public ActionResult SetLocationInSession(int locationID)
//Session.SetDataInSession<int>("location", locationID);
Session["location"] = locationID;
return Json(locationID, JsonRequestBehavior.AllowGet);
public ActionResult GetLocationInSession(string key)
//int locationID = Session.GetDataFromSession<int>(key);
int locationID = (int)Session["location"];
var location = _db.Locations.Find(locationID);
string result = javaScriptSerializer.Serialize(location);
If I run the app locally with debugging I can see that in the SetLocationInSession seems to be executing fine. I hover over session, and it a key count of 1, and the the key is location, and the value is what I expect.
But then when it calls GetLocationInSession I get an object reference error. If I put a break point here, the Session object does not have any keys. Does Umbraco need to interact with the session differently than standard ASP.NET MVC, I have done similar things to this in non Umbraco applications and never had issues.
I'm still not sure why this fixed it, but in case anyone runs into a similar issue, for some reason changing:
to:
int locationID = (int)System.Web.HttpContext.Current.Session["location"];
fixed it for me. I guess it must have been trying to reference some other session. If anyone has any insight on that, I would love to understand what session I was referencing before.
In My layout:
Thanks, Charlie
to:
