  • Chris Clancy 65 posts 134 karma points
    Feb 26, 2018 @ 14:26
    Chris Clancy
    Upgrade to 7.7.8 Azure Web App problems
    I have upgraded successfully from v7.5.7 to v7.7.8 using Visual Studio package console and the application runs fine locally and also if I use Web Deploy to push to Azure.
    However, we usually deploy using TeamCity and even though the build completes without any errors, the Azure web app is broken and I get this error with Custom errors turned off:
    Could not load type 'umbraco.interfaces.IDiscoverable' from assembly 'interfaces, Version=1.0.6219.11988, Culture=neutral, PublicKeyToken=null'.
    Exception Details: System.TypeLoadException: Could not load type 'umbraco.interfaces.IDiscoverable' from assembly 'interfaces, Version=1.0.6219.11988, Culture=neutral, PublicKeyToken=null'.
    If I activate Azure log streaming, I see this message:
     - IIS received the request; however, an internal error occurred during
       the processing of the request. The root cause of this error depends
       on which module handles the request and what was happening in the
       worker process when this error occurred.
     - IIS was not able to access
       the web.config file for the Web site or application. This can occur
       if the NTFS permissions are set incorrectly.
       process configuration for the Web site or application.The
       authenticated user does not have permission to use this DLL.
     - The
       request is mapped to a managed handler but the .NET Extensibility
       Feature is not installed.
    Like I say, this only happens when deploying through Teamcity so I'm confused to say the least.
