  • Ilya 6 posts 95 karma points
    Mar 03, 2018 @ 17:25
    Ilya
    Search Page - what will be better to use for searching. Need you advice.
    Umbraco version 7.5.3 assembly: 1.0.6092.24019
    Hello my friends.
    I need to create a search page.
    My results from String-search should be like List which consist of
    1. Description + link to page or link to file .pdf which can be downloaded.
    2. Description + link to page or link to file .pdf which can be downloaded.
    3. Description + link to page or link to file .pdf which can be downloaded.
    4. Description + link to page or link to file .pdf which can be downloaded.
    Can someone give your valueble ideas on this ?
  • Søren Tidmand 129 posts 366 karma points
    Mar 05, 2018 @ 16:20
    Søren Tidmand
    Hi flya,
    my personal favourite search package is ezSearch, which is using the built-in Lucene index, razor for templating and is highly configurable: https://our.umbraco.org/projects/website-utilities/ezsearch/
    You could also use Examine although it requires a bit more configuration: https://our.umbraco.org/documentation/reference/searching/examine/
    /Søren
  • David Peck 690 posts 1896 karma points c-trib
    Mar 06, 2018 @ 12:03
    David Peck
    If you need to use Examine to index PDFs then check out: https://github.com/umbraco/UmbracoExamine.PDF
    Mar 06, 2018 @ 12:36
    Ilya
    Thank you for your answers. I hope, I can implement and configure search without problems)
    Best Regards
