  • Hassan 79 posts 264 karma points
    Mar 11, 2018 @ 08:37
    Hassan
    Problem in upload EXE file in media section
    Hello.
    I use Umbraco 7.4.3. I uploaded an exe file in media section. The file work and run correctly before upload, but after upload it and download from umbraco website, it does not work!!
    What is the problem? Does Umbraco change file metadata after upload in media section?
    What can I do for solve it?
  • Søren Gregersen 441 posts 1883 karma points MVP 2x c-trib
    Mar 11, 2018 @ 09:38
    Søren Gregersen
    How does it “not work”?
    Normally files downloaded from the internet, are tagged as unsecure in Windows. That’s by design. You can change the property on the downloaded file, in the file properties, if what described above is the case.
    You can always read the code of how umbraco handles file-uploads.
    Mar 11, 2018 @ 10:15
    Hassan
    Hi Søren.
    The file does not run after upload it in media section and download it. It has an error as "This app can not run on your PC. To find a version for your PC, check with the software publisher".
    The file runs correctly before upload, But does not run after upload it. Image of error: enter image description here
  • Asbjørn 82 posts 195 karma points c-trib
    Mar 11, 2018 @ 13:31
    Asbjørn
    This sounds like you're missing an appropriate mime type configurations for .exe files. The web server doesn't know that to do with the file, so the download get corrupted.
    You should add something like this to web.config:
    <system.webServer>
        <staticContent>
        <remove fileExtension=".exe" />
        <mimeMap fileExtension=".exe" mimeType="application/octet-stream" />
        </staticContent>
    </system.webServer>
