  • Alistair Jenkins 92 posts 315 karma points
    Mar 16, 2018 @ 12:54
    Alistair Jenkins
    RedirectToCurrentUmbracoPage() results in Connection error
    The surface controller for a form I have created:
    using ContactForm.Models;
    using System.Net.Mail;
    using System.Web.Mvc;
    using Umbraco.Web.Mvc;
    namespace ContactForm.Controllers
    public class ContactFormController : SurfaceController
        [HttpPost]
        public ActionResult SendMail(ContactFormViewModel model)
            if (!ModelState.IsValid)
                return CurrentUmbracoPage();
            if (ModelState.IsValid)
                return SendMessage(model);
            return Redirect();
        private ActionResult SendMessage(ContactFormViewModel model)
            string str = $"<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Strict//EN\" \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd \"><html xmlns=\"http://www.w3.org/1999/xhtml \"><head></head><body><p>Name: {model.Name}</p> <p>Email: {model.Email}</p> <p>Message: {model.Message}</p></body></html>";
            string sub = $"{model.Subject}";
            MailMessage msg = new MailMessage();
            msg.From = new MailAddress("no-reply@myemail.co.uk");
            msg.To.Add("me@myemail.co.uk");
            msg.Subject = sub;
            msg.Body = str;
            msg.Priority = MailPriority.Normal;
            msg.IsBodyHtml = true;
            SmtpClient client = new SmtpClient();
            client.Send(msg);
            TempData.Add("Success", value: "Your message was successfully sent. We will get back to you as soon as possible");
            return Redirect();
        private ActionResult Redirect()
            return RedirectToCurrentUmbracoPage();
        public ActionResult ContactForm() { return PartialView(""); }
    results in an
    'Umbraco cannot start. A connection string is configured but Umbraco cannot connect to the database."
    error. If I change RedirectToCurrentUmbracoPage() to just CurrentUmbracoPage(), there is no error, but of course the text entered into the form remains, which is what I am trying to avoid. Googled this for a bit but can't seem to find anyone having the same issue. Does anyone have any idea what the problem might be?
    All assistance gratefully received,
    Cheers, Alistair
    Apr 20, 2018 @ 15:10
    Alistair Jenkins
    Hi.
    Still having this problem. My surface controller has changed a bit now due to implementing reCaptcha on the form, but I still have the same issue. Returning RedirectToCurrentUmbracoForm( ) at the end of SendMessage( ) results in an Umbraco cannot start error, while returning CurrentUmbracoPage( ) does not, but leaves the contents of the fields intact, which I want to avoid. Does anyone have any idea why this might be happening? Thanks, Alistair
    using ContactFormView.Models;
    using Umbraco.Web;
    using Newtonsoft.Json;
    namespace ContactFormView.Controllers
    public class ContactFormSurfaceController : SurfaceController
        [HttpPost]
            else
                string EncodedResponse = Request.Form["g-Recaptcha-Response"];
                bool IsCaptchaValid = (ReCaptchaClass.Validate(EncodedResponse) == "true" ? true : false);
                if (!IsCaptchaValid)
                    if (EncodedResponse == "")
                        ModelState.AddModelError("reCAPTCHA", "Please complete the reCAPTCHA.");
                    else
                        ModelState.AddModelError("reCAPTCHA", "The reCAPTCHA is incorrect");
                else
        public class ReCaptchaClass
            public static string Validate(string EncodedResponse)
                var client = new System.Net.WebClient();
                string PrivateKey = "6LfLjxcUAAAAAD3uofXIL0Evj8G3LgG5T04oz3RD";
                var GoogleReply = client.DownloadString(string.Format("https://www.google.com/recaptcha/api/siteverify?secret={0}&response={1}", PrivateKey, EncodedResponse));
                var captchaResponse = JsonConvert.DeserializeObject<ReCaptchaClass>(GoogleReply);
                return captchaResponse.Success;
            [JsonProperty("success")]
            public string Success
                get { return m_Success; }
                set { m_Success = value; }
            private string m_Success;
            [JsonProperty("error-codes")]
            public List<string> ErrorCodes
                get { return m_ErrorCodes; }
                set { m_ErrorCodes = value; }
            private List<string> m_ErrorCodes;
            string emailto = CurrentPage.GetPropertyValue<string>("emailAddressTo");
            msg.From = new MailAddress("no-reply@clearviewnetworks.co.uk");
            msg.To.Add(emailto);
            msg.Subject = sub;
            msg.Body = str;
            client.Send(msg);
            TempData.Add("Success", value: "Your message was successfully sent.");
            TempData.Add("GetBack", value: "We will get back to you as soon as possible.");
        public ActionResult ContactForm() => PartialView("/Views/ContactForm/ContactForm.cshtml");
    Apr 27, 2018 @ 07:59
    Alistair Jenkins
    Is there really no-one who has any idea about this?
    This is my connection string btw. Works ok the rest of the time.
    <add name="umbracoDbDSN" connectionString="server=CVN-WIN10-AL;database=myDatabase;user id=myUserId;password='myPassword'" providerName="System.Data.SqlClient"/>
  • Mark 91 posts -18 karma points
    Apr 27, 2018 @ 09:22
    Mark
    Does the site work without this controller being fired?
    Are you sure the connection issue is caused by the controller?
    Apr 27, 2018 @ 09:29
    Alistair Jenkins
    HI Mark,
    The site works fine without the controller being fired. The controller works fine if I use 'return CurrentUmbracoPage();'. The issue only occurs when I use 'return RedirectToCurrentUmbracoPage();' The solution may lie elsewhere I suppose but I don't know enough to know where and why and googling this hasn't made things any clearer.
