Simple injection not working after forced restart. Need to delete App_Data/Temp/PluginCache and iisreset to make it work
Hi all,
For my project i am using Simple Injection. Everything works fine. The interfaces are set the website is running.
But when i change something in the web.config or the website is forced to restart then simple injection is not working anymore and there is error on the website.
After a lot of troubleshooting i found the cause of it was the "PluginCache"after deleting that folder and a IIS reset. The website is working and the PluginCache is regenerated.
Does anyone have a solution for it had the same problem? I hope you guys can help me out
Hi all,
