  • Martin 278 posts 662 karma points
    Mar 20, 2018 @ 13:32
    Martin
    Navigation - Check If Children Are Visible
    Hi All,
    I'm looking for some help with filtering a navigation dropdown.
    I have a umbracoNaviHide property on each document type. I want to be able to check if a level 3 child is visible.
    Ive added .Where("Visible") to the if statement instead of Any(), but I get the error -
    Cannot implicitly convert type 'System.Linq.IQueryable
    Any help would be grateful.
    Martin
     @foreach (var level3 in level2.Children.Where("Visible"))
            if (level3.Children.Any())
                <li class="has-children">
                    <a href="#3">I Have Children</a>
                </li>
            else
                <li>
                    <a href="">I Have No Children or All Children Are Hidden </a>
                </li>
    Mar 20, 2018 @ 13:37
    Alex Skrypnyk
    Hi Martin
    Use this code:
    @foreach (var level3 in level2.Children.Where(x => x.IsVisible()))
        if (level3.Children.Where(x => x.IsVisible().Any())
            </li>
        else
            <li>
            </li>
    By the way, what is the type of level2?
    Alex
    Mar 20, 2018 @ 13:48
    Martin
    Hi Alex,
    Thanks for that.
    Yeah my level 2 is just the same. I dont think i could use a helper, as each level has a different styling. So it was easier to just build out each level.
