  • Matt 359 posts 842 karma points
    Mar 21, 2018 @ 15:36
    Matt
    Issue with upgrading on localhost
    We're having issues with upgrading our umbraco install on local host I will try explain best I can.
    So we're running a local host version of umbraco which is under SourceSafe.
    My colleague upgraded the umbraco project from version 7.8.1 to 7.9.2 which the upgrade worked perfectly and showed no errors.
    Hes then checked his documents in SourceSafe which I've then connected my path and got the latest version (his version) of the project.
    When i then run the solution I get propt with the following error;
    As you can see its now saying my version is 7.9.2 but is now upgrading (downgrading) to 7.8.1 which is very confusing.
    I then just click continue as I cant do anything else which I then get prompt with the next error. enter image description here
    I dont understand why its prompting me to upgrade as my colleague has done this already and I've got the same install as him?
    Any help would be appreciated :)
    Matt
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Mar 21, 2018 @ 16:13
    Nik
    Hi Matt,
    My initial thoughts would be that your local version still has the 7.8.1 dll in the bin directory and not the updated 7.9.2 dll.
    Can you check if that is the case or not? Also, can you check what version your web config says it is running?
    Finally, how is your project set up? Is it a Website or is it a Web Application? And how is Umbraco installed? Is it via nuget?
    Nik
    Mar 21, 2018 @ 16:48
    Matt
    Hello Nik
    Thanks for that! the .dll was indeed not showing the correct version. It was installed via nuget.
    The issue was the project was pointing to the old package
     <Import Project="..\packages\UmbracoCms.7.9.2\build\UmbracoCms.props" Condition="Exists('..\packages\UmbracoCms.7.9.2\build\UmbracoCms.props')" />
    Matt
