I have added reCaptcha V2 to my working contact form as per
this blog entry. However when I try to submit the form with the reCaptcha successfully completed I get the "Please complete the reCAPTCHA" error message which is thrown when the response is null or empty. Here are my model, view and controller with the code from the site added.
ContactFormViewModel.cs
using System.ComponentModel.DataAnnotations;
namespace ContactForm.Models
public class ContactFormViewModel
public string Name { get; set; }
[Required(ErrorMessage = "Please enter your email")]
[EmailAddress(ErrorMessage = "The email given is not a valid email address. Please try again.")]
public string Email { get; set; }
public string Subject { get; set; }
public string Message { get; set; }
Back in now, and I've been trying to get this to work and in my attempts to get round various errors have ended up with the following:
namespace ContactFormView.Models
ContactFormSurfaceController.cs
using ContactFormView.Models;
using System.Net.Mail;
using System.Web.Mvc;
using Umbraco.Web;
using Umbraco.Web.Mvc;
using Recaptcha.Web;
using Recaptcha.Web.Mvc;
namespace ContactFormView.Controllers
public class ContactFormSurfaceController : SurfaceController
public string GetViewPath(string name)
return string.Format("/Views/{0}.cshtml", name);
[HttpGet]
public ActionResult RenderForm()
ContactFormViewModel model = new ContactFormViewModel();
return PartialView(GetViewPath("ContactUsPage2"), model);
[HttpPost]
public ActionResult RenderForm(ContactFormViewModel model)
[HttpPost]
public ActionResult SubmitForm(ContactFormViewModel model)
RecaptchaVerificationHelper recaptchaHelper = this.GetRecaptchaVerificationHelper();
if (string.IsNullOrEmpty(recaptchaHelper.Response))
ModelState.AddModelError("reCAPTCHA", "Please complete the reCAPTCHA");
return CurrentUmbracoPage();
else
RecaptchaVerificationResult recaptchaResult = recaptchaHelper.VerifyRecaptchaResponse();
if (recaptchaResult != RecaptchaVerificationResult.Success)
ModelState.AddModelError("reCAPTCHA", "The reCAPTCHA is incorrect");
bool success = false;
if (ModelState.IsValid)
success = SendEmail(model);
TempData["FormResult"] = success;
return RedirectToCurrentUmbracoPage();
public bool SendEmail(ContactFormViewModel model)
string str = $"<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Strict//EN\" \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd \"><html xmlns=\"http://www.w3.org/1999/xhtml \"><head></head><body><p>Name: {model.Name}</p> <p>Email: {model.Email}</p> <p>Message: {model.Message}</p></body></html>";
string sub = $"{model.Subject}";
string emailto = CurrentPage.GetPropertyValue<string>("emailAddressTo");
MailMessage msg = new MailMessage();
msg.From = new MailAddress("no-reply@clearviewnetworks.co.uk");
msg.To.Add(emailto);
msg.Subject = sub;
msg.Body = str;
msg.Priority = MailPriority.Normal;
msg.IsBodyHtml = true;
SmtpClient client = new SmtpClient();
client.Send(msg);
TempData.Add("Success", value: "Your message was successfully sent.");
TempData.Add("GetBack", value: "We will get back to you as soon as possible.");
return true;
On your form make sure you have the following HTML:
<div class="g-recaptcha" data-sitekey="YOUR SITE KEY HERE"></div>
Within your form submission method add the following:
var response = Request["g-recaptcha-response"];
string secretKey = YOUR SECRET KEY HERE;
var client = new WebClient();
var result = client.DownloadString(string.Format("https://www.google.com/recaptcha/api/siteverify?secret={0}&response={1}", secretKey, response));
var obj = JObject.Parse(result);
var status = (bool)obj.SelectToken("success");
if(!status)
//ADD CODE HERE THAT YOU WANT TO HAPPEN IF THE CAPTCHA FAILS
Well, I've tried implementing your code. I went back to the first version I had, to avoid the problems with RenderForm() I was having in the second version. I put in the script and div tags where you suggested and altered my controller to the code below:
using Umbraco.Web;
using Newtonsoft.Json.Linq;
[HttpPost]
public ActionResult SendMail(ContactFormViewModel model)
if (!ModelState.IsValid)
else
string secretKey = "my private key";
var client = new System.Net.WebClient();
if (!status)
else
return SendMessage(model);
private ActionResult SendMessage(ContactFormViewModel model)
msg.Subject = sub;
msg.Body = str;
client.Send(msg);
return Redirect();
private ActionResult Redirect() => RedirectToCurrentUmbracoPage();
public ActionResult ContactForm() { return PartialView("ContactUsPage2"); }
But now the page just hangs on loading. It never loads and it never throws an error. Any idea why?
You should add a break point to the first line of your method. Then run debugger to step through each line of code. You will be able to see where it is hanging.
Right. I've finally sorted out the @Html.Action problem and the reason for it is too embarrasing an error to repeat here, especially as it doesn't relate to the initial topic of the post. Suffice to say that my form now displays as before, with the reCaptcha at the bottom. However, I still have the same problem with your solution, ie It doesn't matter if I check the reCaptcha or not, clicking the send button results in the message "The reCaptcha is not correct" and no email is sent. Any ideas?
I'm rushed for time but i thought i would share my code to see if it helps you around the problem as i have implemented recaptcha many times using the same methods!
This submits to the controller of 'ContactController' to the method of 'SendForm'
public ActionResult SendForm(ContactModel Model)
if (string.IsNullOrEmpty(response))
return RedirectToUmbracoPage(FailedId);
var secretKey = ConfigurationManager.AppSettings["recaptchaPrivateKey"].ToString();
if (!status)
//Google recaptcha must be valid to reach this far
//send form magic
else
Although i have missed parts out hopefully this will help!
Let me know if you have any more issues questions!
I managed to work out how to capture the error code from reCaptcha and it was:
missing-input-response - The response parameter is missing
Below is the latest version of my controller, hacked about in an attempt to get the error-codes. Can anybody tell me why the response isn't getting passed to Google? I haven't included the SendMessage() section as it remains the same as before. SendMail() is what's being called initially.
using Umbraco.Web;
using Newtonsoft.Json;
using System;
using System.Diagnostics;
using System.IO;
using System.Text;
public class ReCaptchaClass
public static string Validate(string EncodedResponse)
string PrivateKey = "6LfLjxcUAAAAAD3uofXIL0Evj8G3LgG5T04oz3RD";
var GoogleReply = client.DownloadString(string.Format("https://www.google.com/recaptcha/api/siteverify?secret={0}&response={1}", PrivateKey, EncodedResponse));
var captchaResponse = JsonConvert.DeserializeObject<ReCaptchaClass>(GoogleReply);
var errorlist = captchaResponse.ErrorCodes;
if (errorlist.Count != 0)
Console.SetOut(new DebugTextWriter());
errorlist.ForEach(Console.WriteLine);
else
Console.WriteLine("No errors from reCaptcha");
return captchaResponse.Success;
[JsonProperty("success")]
public string Success
get { return m_Success; }
set { m_Success = value; }
private string m_Success;
[JsonProperty("error-codes")]
public List<string> ErrorCodes
get { return m_ErrorCodes; }
set { m_ErrorCodes = value; }
private List<string> m_ErrorCodes;
[HttpPost]
else
string EncodedResponse = Request.Form["g-Recaptcha-Response"];
bool IsCaptchaValid = (ReCaptchaClass.Validate(EncodedResponse) == "true" ? true : false);
if (!IsCaptchaValid)
else
Got it! It wasn't a problem with the controller at all. The div containing the reCaptcha was on the partial view that called the form using the @Html.Action rather than on the form view itself. So
couldn't find the g-recaptcha-response textarea where the response is stored.
Now I've got a separate problem that the email sends ok but I get a YSOD rather than being redirected to the current page. But that's for another thread. Hope it doesn't take as long to work out!
I am so frustrated with this reCAPTCHA V2 using MVC in Umbraco v8.x.x. It does not check or validate recaptcha at all. It simply submit the form with no message. Please help.
I used recent latest video of creating Contact form and client dependency Umbraco v8 on youtube, When i submit the form it doesn't validate the Recaptha field.
using Project.Core.Services;
using Project.Core.ViewModels;
using System.Web;
using Umbraco.Web;
namespace Project.Core.Controllers
public class ContactSurfaceController : SurfaceController
private readonly ISmtpService _smtpService;
public ContactSurfaceController(ISmtpService smtpService)
_smtpService = smtpService;
[HttpGet]
ContactViewModel model = new ContactViewModel() { ContactFormId = CurrentPage.Id };
return PartialView("~/Views/Partials/Contact/contactForm.cshtml", model);
[HttpPost]
public ActionResult RenderForm(ContactViewModel model)
[HttpPost]
public ActionResult SubmitForm(ContactViewModel model)
else
success = _smtpService.SendEmail(model);
var contactPage = UmbracoContext.Content.GetById(false, model.ContactFormId);
var successMessage = contactPage.Value<IHtmlString>("successMessage");
var errorMessage = contactPage.Value<IHtmlString>("errorMessage");
return PartialView("~/Views/Partials/Contact/result.cshtml", success ? successMessage : errorMessage);
and my View Model:
public class ContactViewModel
[Required(ErrorMessage = "Please enter your name")]
[Required(ErrorMessage = "please enter your email address")]
[EmailAddress(ErrorMessage = "you must enter a valid email address")]
[Required(ErrorMessage = "please enter your message")]
[MaxLength(length: 500, ErrorMessage = "Your message must be no longer than 500 characters")]
@*[Required(ErrorMessage = "please confirm you are human")]
public string ErrorMessageCaptcha { get; set; }*@
public int ContactFormId { get; set; }
reCaptcha not recognising successful response
I have added reCaptcha V2 to my working contact form as per this blog entry. However when I try to submit the form with the reCaptcha successfully completed I get the "Please complete the reCAPTCHA" error message which is thrown when the response is null or empty. Here are my model, view and controller with the code from the site added.
ContactUsPage2.cshtml
ContactFormController.cs
If anyone can shed light on why this isn't working, I'd be grateful.
Thanks, Alistair
Here is what I did on my most recent project:
Hi Paul,
Thanks for this. Sadly I have to head home now, but I'll pick this up next Friday when I'm back in.
Cheers, Alistair
But on loading the page I get this error
Is there nobody who can shed light on this for me?
Yours hopefully, Alistair
Hi Alistair,
Without the use of your helper library there is another way to achieve this functionality.
Within your webpage head section you will need:
Hi Marc,
Cheers, Alistair
Hi Alistair,
Have you tried stepping through your code with debugger to see what part is hanging?
Marc
Hi Marc,
Do you mean in Visual Studio. I'm fairly new to VS so it's not something I've tried before, but I'll try that and see how I go.
Cheers, Alistair
Hi Marc,
OK, The
in my partial view threw an unhandled exception
so I think I had created a loop with
which was the result of hacking about to try and solve a previous problem.
So I've changed the @Html.Action to
But now I get the error
But I have this in my controller
Is that not a public action method called SendMail?
Hi Marc,
Cheers, Alistair
Hi Alistair,
Form in view:
/Lewis
Thanks for all the help.
Cheers, Alistair
Hi Gurus,
and my View Model:
and my Partial View
