I had setup Forms Authentication for my mvc5 application, now i want to setup ExternalLogin authentication for this Application.
So when I tried to setup externalLogin for application when i hit the extenal Login Like Google in Login page the flow again redirecting to Login
I tried the ExternalLogin by removing the code from web.config
<authentication mode=Forms><forms name="yourAuthCookie" loginUrl="login.aspx" protection="All" path="/" ></authentication>
Then the externallogin worked but the normal login(forms authentication) is not working
Hi Rajdeep, I am not sure that this is possible. I have similar scenarion on my project and I use UmbracoIdentity which uses different approach for login in Members and makes possible external login as google or fb.
Mila
Forms Authentication And External Authentication In same project Not working
Mila
